David_H Posted September 16, 2019 Report Posted September 16, 2019 A previous owner removed the original sweep clock from the panel. As such, I've been looking through threads to find opinions on clocks and haven't been able to find much that's recent. Feel free to let me know if I've overlooked a thread though. It would be nice to find a clock to go in the panel that will be IFR legal and usable. My current short-list is below. Any opinions, suggestions, or clocks to avoid? * Davtron M800: 800-14V, Illuminated Buttons, Battery Holder.... $300.00 * Flight Data GT-50.... $169.00 * EI SC-5 Superclock... $285.00 * EI ASC-5A Superclock... $580.00 Quote
hypertech Posted September 16, 2019 Report Posted September 16, 2019 The next time I have someone in my panel, I'm going to have my clock swapped out with an MD93 so I have a charging port on that side of the plane. A certified charging port alone for some reason seems to cost $300+ so this way I get that and the clock requirement taken care of in less space. 1 Quote
carusoam Posted September 16, 2019 Report Posted September 16, 2019 Add aerovonics and mid continent to your search... Get one with USB sockets... Some popular options discussed lately.... Best regards, -a- Quote
David_H Posted September 16, 2019 Author Report Posted September 16, 2019 A Stratus USB Charging Port is also being installed in the panel. It seemed like it might be a good idea to keep the USB charging ports and the clock separated. I wouldn't want cables to be in the way if I were to want to time an approach. 1 Quote
bob865 Posted September 16, 2019 Report Posted September 16, 2019 I installed the GT-50. Nice little unit and the cheapest of the bunch. I liked it because I didn't have a volt meter, and it added that functionality. That alone has already saved my butt. I was doing an IFR training flight at night on an ILS approach (VFR conditions) and it started flashing in my face. My alternator breaker had tripped and I didn't know. The voltage annunciator (idiot light) was flashing, but at low RPM and high load, it's not uncommon for it to flash even with no issue; so I had ignored it. Then the GT-50 started flashing. I was able to unload the system and land so I could troubleshoot on the ground. The original plan was to go missed and fly home so I knew I needed the time on the ground. Luckily it was just a breaker reset. Otherwise I would have started troubleshooting in flight when my radios and lights went out. The ground was a much nicer place to troubleshoot. :) Quote
hypertech Posted September 16, 2019 Report Posted September 16, 2019 27 minutes ago, David_H said: A Stratus USB Charging Port is also being installed in the panel. It seemed like it might be a good idea to keep the USB charging ports and the clock separated. I wouldn't want cables to be in the way if I were to want to time an approach. I think that if I were in a position to have to time an approach, my whole panel would have to be nearly dead in which case I can unplug the cord and run on the ipad battery for the approach. The only thing I actually use the clock for is clearance void times and timing 1 minute for the LOP mag test for Savvy. Quote
moontownMooney Posted September 16, 2019 Report Posted September 16, 2019 I just recently purchased the SC-5. I cant give a PIREP becuase I havent flown with it yet. For me it was the best compromise of functionality and price. I liked the idea of the interval timer as a reminder to switch tanks.Sent from my LM-V405 using Tapatalk Quote
Igor_U Posted September 17, 2019 Report Posted September 17, 2019 when I redo my panel, I will install the GT-50. Two reason for that: Price G meter. And I'll keep 8-day mechanical clock in my yoke. Quote
David_H Posted September 17, 2019 Author Report Posted September 17, 2019 (edited) A Davtron M803 is now on the way. It'll occupy the space that the M303 currently resides in. I probably would have selected the GT-50 if it wouldn't have been for the OAT. The GT-50 really looks to be the best deal of the bunch. Edited September 17, 2019 by David_H Quote
GeeBee Posted September 18, 2019 Report Posted September 18, 2019 The MD-93 is the bomb. I had one in my PA-18. Easy to use, nice big and clear LED digits. Not a lot of buttons to push to make it work. I wish I had one in my Ovation even if it does have a G1000. I am even considering ways I can get one mounted in. Quote
bob865 Posted September 18, 2019 Report Posted September 18, 2019 22 hours ago, David_H said: A Davtron M803 is now on the way. It'll occupy the space that the M303 currently resides in. I probably would have selected the GT-50 if it wouldn't have been for the OAT. The GT-50 really looks to be the best deal of the bunch. The GT-50 does have OAT FWIW. 1 Quote
David_H Posted September 18, 2019 Author Report Posted September 18, 2019 Just now, bob865 said: The GT-50 does have OAT FWIW. I completely overlooked the OAT feature on the GT-50. Quote
FlyingScot Posted September 19, 2019 Report Posted September 19, 2019 Keep in mind too that Reg’s do not require a standalone clock - even for IFR. A clock permanently installed clock visible to the pilot is required for IFR, but the requirement can be satisfied by a GMT clock function on an existing installed instrument - e.g. the clock on the 430W satisfies the requirement - BTW I did confirm this with AOPA legal - Quote
