Guest Posted August 31, 2019 Report Posted August 31, 2019 A friend of mine with a GNS480 in his plane is having “loss of integrity” with it. We installed mine in his plane to test the airframe side of the system, it works fine. Garmin has stopped support of these unit in June of this year. Does anyone know of any Avionics shop who have or will work on them? Clarence Quote
Guitarmaster Posted August 31, 2019 Report Posted August 31, 2019 A friend of mine with a GNS480 in his plane is having “loss of integrity” with it. We installed mine in his plane to test the airframe side of the system, it works fine. Garmin has stopped support of these unit in June of this year. Does anyone know of any Avionics shop who have or will work on them? Clarence You might try The Avionics Place in Rockford, ilSent from my Pixel 2 XL using Tapatalk Quote
Lee Moore Posted August 31, 2019 Report Posted August 31, 2019 Any Garmin authorized service center can work on the installation. Garmin only ran out of components to repair the unit. They still support it with databases, tech data, and can even help a dealer sort out installation issues. Quote
Guest Posted August 31, 2019 Report Posted August 31, 2019 4 hours ago, Guitarmaster said: You might try The Avionics Place in Rockford, il Sent from my Pixel 2 XL using Tapatalk Thanks, Will check with them. Clarence Quote
Guest Posted August 31, 2019 Report Posted August 31, 2019 3 hours ago, Lee Moore said: Any Garmin authorized service center can work on the installation. Garmin only ran out of components to repair the unit. They still support it with databases, tech data, and can even help a dealer sort out installation issues. Thanks, The installation was proven with another unit. The unit itself requires repair which Garmin can't/won't do anymore. Clarence Quote
jasona900 Posted August 31, 2019 Report Posted August 31, 2019 8 hours ago, M20Doc said: A friend of mine with a GNS480 in his plane is having “loss of integrity” with it. We installed mine in his plane to test the airframe side of the system, it works fine. Garmin has stopped support of these unit in June of this year. Does anyone know of any Avionics shop who have or will work on them? Clarence Check the antenna connection on the back of the mounting bracket. Mine comes loose every now and then due to vibration.. a quick wiggle and problem solved. Quote
Awful_Charlie Posted September 1, 2019 Report Posted September 1, 2019 Try asking on the yahoo "gns480 users" group - it is likely it has been seen before, and there may be more than one solution tried and tested Quote
kortopates Posted September 2, 2019 Report Posted September 2, 2019 (edited) Clarence, since you've isolated the issue to the GNS480 itself, I believe you're out of luck. These units aren't field repairable, their service model is limited to returning them to garmin for repair, nobody but Garmin has the necessary documentation. But its probably worthwhile having a Garmin dealer make sure the problem unit is properly configured before giving up. But its not hard to verify the configuration of the problem unit and configure your other known good unit as a proper test. Edited September 2, 2019 by kortopates Quote
