Open4cycle Posted August 11, 2019 Report Posted August 11, 2019 I bought this M20F with ESG transponder and ads-b 2i installed. Everything works great other than the 2i receiver gps light blinks amber and it doesn’t acquire gps signal. The 2i does power up and it does receive ADS-B signal and it will connect to my iPad. The ESG does receive a gps signal and usually a strong signal on all 12 stations. So now the wires from the ESG 37 pin connector have been traced to all connections and continuity checked especially on all 6 connections to the 9pin. With the ESG installed and powered on there is a ground at pin#8 5vdc on pin #1 #2 #3. 6.7vdc on pin #7 6.1vdc on pin #6. The receiver has been swapped out with another workin 2i still no gps signal with either receiver. The receiver is at the latest update and the ESG is set to both uat and 1090 in on the setup screen. The ESG software update is at rev 5 (latest is 7)and the hardware update is at rev 4 (latest is 5). The local installer tells me this should make no difference for resolving the issue. The local installer made all of these checks and so have I. The local installer wants me to leave it with him so he can take the trey out of the panel and go through the connectors again.I don’t like to leave the aircraft with him because he has bent the nose gear once before after I told him I didn’t want him towing it. His 9yo son drives the tow bar with a 4 wheeler! So I’m asking if there might be an issue with the update on the ESG or is there something else I may be missing? Oh and the bit codes are all 0’s. Thanks, Scott Quote
