8 minutes ago, Lloyd Babcock said:
The heater control on my Ovation is stuck on, any one know a quick fix
Oh that's not good - in the middle of a heat wave.
If the cable is stuck.  You could undo the adjustment on the slide gate valve thing under the cowl.   Manually move the gate.   Retighten the cable adjustment point.
There is no fix without pulling the cowling. If you do, you'll probably readily see what the problem is and one of the two suggestions above should fix it, even if only temporarily.
