Danb Posted September 10, 2018 Report Posted September 10, 2018 I attended a MAPA. clinic this weekend, My Bravo experienced backfiring on rollout, stopped takeoff, did good runup again, all seemed normal. On takeoff I heard what I thought was backfiring checked engine analyzer cyl no 1 egt was 1600 I was at 300 ft landed uneventful. The guys on the ground heard the backfiring and watched what was up. Being Saturday morning I couldn’t find any one to work or check it out. MHT being a bigger airport had no one I left some messages for maintenance there call a place at Nashua no luck. I suspect a partially clogged injector, valve, induction leak. Egt elevated, thought we saw a elevated cht on no1 earlier in the day opened cowl flaps then later on takeoff this event. New Hampshire Guys Im listening for advice at Manchester
Mjknick@gmail.com Posted September 10, 2018 Report Posted September 10, 2018 Any good mechanic should be able to help you and you deductions sound spot on. Start with cleaning injectors. I’m in Camarillo CA so no local recommendations for Manchester NH. Best of luck. Sent from my iPhone using Tapatalk
Ned Gravel Posted September 10, 2018 Report Posted September 10, 2018 Dan: When I had engine probs in Manchester last time, it was only for the manifold pressure line, so not as serious as yours, but still had to take the plane to Concord to their local shop. Took two hours to get it replaced. In Manchester, there is an itinerant mechanic that comes in to Signature on request, but he was not available for me two years ago. You may wish to ask Signature if their guy is still doing this or phone the shop in Concord to see if they know someone local. It was nice meeting you and I hope you get going OK. Personally, I had a great flight into demanding conditions when I flew out of Manchester, and I did not make it to my desired destination because of minima there. But I made it to the flight planned destination. I had to leave the plane in Allentown, PA, but I know it is OK. Hope yours gets to be OK soon. Good luck.
Danb Posted September 10, 2018 Author Report Posted September 10, 2018 Thanks Ned, I found a mechanic on the NE end of MHT, they will retrieve the plane this morning and start. Having just worked on emergency procedures the hour before is enlightening. Now I need to get back to Manchester, anyone up for takeing me back from Wilmington De
Marauder Posted September 10, 2018 Report Posted September 10, 2018 Thanks Ned, I found a mechanic on the NE end of MHT, they will retrieve the plane this morning and start. Having just worked on emergency procedures the hour before is enlightening. Now I need to get back to Manchester, anyone up for takeing me back from Wilmington De Sorry I can’t help. Try Chris D. He might be game for a post annual trip. Need his contact info?Sent from my iPad using Tapatalk Pro
Danb Posted September 10, 2018 Author Report Posted September 10, 2018 Sure the wx stinks, where’s yours.. Plane is fixed, partially clogged injector
Marauder Posted September 10, 2018 Report Posted September 10, 2018 Sure the wx stinks, where’s yours.. Plane is fixed, partially clogged injector Mine is napping in my hangar. I’ll text you Chris’s contact information.Sent from my iPad using Tapatalk Pro
Seymour Posted September 11, 2018 Report Posted September 11, 2018 (edited) Dan, It was good to meet you and I'm glad you connected with the on-field mechanic and got it fixed quickly. Sorry I can't help with the travel back here; Wx is forecast to be well beyond my limits for the next week. (even in perfect weather the trip itself is still beyond my current capabilities) Dave Edited September 11, 2018 by Seymour
Danb Posted September 11, 2018 Author Report Posted September 11, 2018 Thanks Dave and Chris, of course the wx stinks and how bout Florence...I’m checking this morning trying to get a hanger in Manchester
carusoam Posted September 12, 2018 Report Posted September 12, 2018 Dan, If you get a chance... See the thread by @scottd regarding the latest aviation weather for Florence... Scott is our WeatherSpork guy. Best regards, -a-
Danb Posted September 12, 2018 Author Report Posted September 12, 2018 Anthony I subscribe to WeatherSpork, a great wx program.. 1
