JoshMan Posted September 6, 2018 Report Posted September 6, 2018 Hey, guys. Hoping to get your thoughts on an issue I've had over the last couple days. I took my 1969 M20E in for a pitot/static test two days ago and on the way home my gear initially failed to retract. I hit 110 MPH and they retracted. I flew home and gear extended no problem. We put the plane on jacks yesterday and the gear are retracting at 110 MPH. I flew with mechanic today and they once again failed to retract until 110 MPH. We were pretty much certain it was the airspeed pressure switch at this point until we did some retractions/extensions in the air at 3000 ft. The gear would retract just fine at 90 MPH while at altitude. We came back and landed, departed again, and the gear would not retract until about 110 MPH. We are still pretty set on the airspeed limit switch considering it happened immediately after the pitot/static test but the fact that the gear will retract at lower air speeds at altitude does not make sense. Do you guys have any thoughts? I have no squat switch or bypass mechanism. Thanks. Josh
N201MKTurbo Posted September 6, 2018 Report Posted September 6, 2018 It is possible the guy doing the pitot static test accidentally shocked the static system damaging the airspeed switch. 1
JoshMan Posted September 6, 2018 Author Report Posted September 6, 2018 2 minutes ago, N201MKTurbo said: It is possible the guy doing the pitot static test accidentally shocked the static system damaging the airspeed switch. I agree, but it does not make sense that it will not retract until 110 on take off but will retract at lower airpeeds at altitude?
N201MKTurbo Posted September 6, 2018 Report Posted September 6, 2018 Does your plane have an ASSS? I don’t think they were standard on the 69. It may have nothing to do with the static test.
JoshMan Posted September 6, 2018 Author Report Posted September 6, 2018 10 minutes ago, N201MKTurbo said: Does your plane have an ASSS? I don’t think they were standard on the 69. It may have nothing to do with the static test. If ASSS is the same thing as an airspeed pressure switch then yes. Here is a picture
Yetti Posted September 6, 2018 Report Posted September 6, 2018 For grins if you have an alt statc valve. Make sure the testing guys buttoned up the system properly when done 1
JoshMan Posted September 6, 2018 Author Report Posted September 6, 2018 Thanks, guys. New switch is on the way. Will let you know what comes of it. Josh
JoshMan Posted September 6, 2018 Author Report Posted September 6, 2018 9 minutes ago, Freemasm said: Maybe you found something we don’t know but I would have held off on a new ASSS just yet. You have to remove the old one anyway so why not take it out and wring it out on the bench? They are stone simple. It always kills me to spend money that doesn’t solve the issue, though I should be used to it by now. Let us know what you find. Thats a fair point. The MSC I use is a 2 hour flight, so I just had them buy the part to avoid multiple trips. I figure the part is 50 years old. Wont hurt to replace it. 1
JoshMan Posted September 7, 2018 Author Report Posted September 7, 2018 What are odds you guys know if the ASSS is normally open or normally closed switch?
65C_flier Posted September 7, 2018 Report Posted September 7, 2018 On 9/6/2018 at 2:13 PM, JoshMan said: Hey, guys. Hoping to get your thoughts on an issue I've had over the last couple days. I took my 1969 M20E in for a pitot/static test two days ago and on the way home my gear initially failed to retract. I hit 110 MPH and they retracted. I flew home and gear extended no problem. I had the exact same issue last week. After the IFR recert the gear wouldn't come up until 97mph (up from 85mph before recert). I also have the Dukes 3203-00 and came to the same conclusion that it was the issue. During troubleshooting it retracted at 87mph at 3000ft, but is solid at 97 during takeoff...
JoshMan Posted September 7, 2018 Author Report Posted September 7, 2018 36 minutes ago, mbiggs said: I had the exact same issue last week. After the IFR recert the gear wouldn't come up until 97mph (up from 85mph before recert). I also have the Dukes 3203-00 and came to the same conclusion that it was the issue. During troubleshooting it retracted at 87mph at 3000ft, but is solid at 97 during takeoff... Did you end up replacing your dukes?
JoshMan Posted September 7, 2018 Author Report Posted September 7, 2018 49 minutes ago, mbiggs said: No, hoping to get it adjusted Do you know for sure it is adjustable?
SLOWR426 Posted November 23, 2020 Report Posted November 23, 2020 On 9/7/2018 at 1:28 PM, JoshMan said: Do you know for sure it is adjustable? Josh, did the new air speed pressure switch fix your take-off gear retraction issue? Do you happen to have P/N and place you bought it? 1
carusoam Posted November 23, 2020 Report Posted November 23, 2020 7 minutes ago, SLOWR426 said: Josh, did the new air speed pressure switch fix your take-off gear retraction issue? Do you happen to have P/N and place you bought it? While we wait for Josh to respond... Consider placing a call to Dan at Lasar... MSC and parts available for all Mooney airplanes... Dan IS the man... The switch is also or probably OH’able... searching for who does this type of work shouldn’t be too hard... There is an article on servicing that switch by a really good Mooney Mechanic... I read it recently, so there is probably a link around here too... Best regards, -a- 1
SLOWR426 Posted November 23, 2020 Report Posted November 23, 2020 Just now, carusoam said: While we wait for Josh to respond... Consider placing a call to Dan at Lasar... MSC and parts available for all Mooney airplanes... Dan IS the man... Best regards, -a- What is MSC? The industrial supplies distributor? Mooney something? Thanks
carusoam Posted November 23, 2020 Report Posted November 23, 2020 14 minutes ago, SLOWR426 said: Josh, did the new air speed pressure switch fix your take-off gear retraction issue? Do you happen to have P/N and place you bought it? Slow, I added a few more lines regarding the switch above... There is some common-ish maintenance that can be done... so a new one may not be required... They are terribly expensive, brand new... I gave enough detail, that some basic search should find what you are looking for... If not, let us know how far you got... The MSC.... is a Mooney Service Center.... a place you can go to buy all kinds of parts for your Mooney... Dan at Lasar happens to be the world specialist in all things Mooney part related... Lasar supports Mooneys around the world... To find a list of MSCs go to Mooney.com and work your way through the menu system they have... the website is under transition... so it isn’t perfect yet... Best regards, -a-
Ragsf15e Posted November 24, 2020 Report Posted November 24, 2020 If the gear retraction is specific to an airspeed, obviously the Asss is the most likely culprit and worth checking. However, I wouldn’t assume it’s the problem without testing. Especially this time of year (colder) there may be “delayed” retraction events... it may look like the Asss switch is set around 110 or so, but maybe it’s just 10” after gear switch actuation. This can be caused by sticky limit switches in the belly. Mine took some LPS 1/2 and toggling, good for another year. If you have a weight on wheels switch, either the switch or the gear donuts can be a culprit, especially in the cold. 1
carusoam Posted November 24, 2020 Report Posted November 24, 2020 Great seasonal memory Rags! Its cold out! We have either the Asss or the squats... The airspeed sensor switch is in most of the newer Mooneys... The squat switch is in the first electric gear Mooneys... The Donuts are temperature sensitive when it comes to their rebound quality... A good cold day will keep the switch and donuts from working properly... Either new donuts, or switch calibration can be the answer... switch calibration costs about 1amu less... PP memories returning only... could be fuzzy memories... Best regards, -a-
Hank Posted November 24, 2020 Report Posted November 24, 2020 48 minutes ago, carusoam said: Great seasonal memory Rags! Its cold out! We have either the Asss or the squats... The airspeed sensor switch is in most of the newer Mooneys... The squat switch is in the first electric gear Mooneys... The Donuts are temperature sensitive when it comes to their rebound quality... A good cold day will keep the switch and donuts from working properly... Either new donuts, or switch calibration can be the answer... switch calibration costs about 1amu less... PP memories returning only... could be fuzzy memories... Best regards, -a- An electric heater on the left main gear will help the pucks expand and hit the switch. Give it an hour or so . . . Don't do this under a leaky tank . . . . But eventually the pucks will need to be replaced. Then it will taxi like a car, and your landings will suddenly be much more graceful. 2
JoshMan Posted November 28, 2020 Author Report Posted November 28, 2020 On 11/23/2020 at 6:02 PM, SLOWR426 said: Josh, did the new air speed pressure switch fix your take-off gear retraction issue? Do you happen to have P/N and place you bought it? Hey! Sorry for delay. The airspeed switch did fix this issue. I am out of town but can get you P/N when I get home this week!
65C_flier Posted November 28, 2020 Report Posted November 28, 2020 The Dukes air switch on my 65C was 3203-00. It was adjustable by screwing the switch in/out (remember to loosen the grub screw). Later models had a different part number i believe.
redrider54 Posted February 20, 2024 Report Posted February 20, 2024 On 11/28/2020 at 11:20 AM, JoshMan said: Hey! Sorry for delay. The airspeed switch did fix this issue. I am out of town but can get you P/N when I get home this week! Do you happen to have this Part Number or where you got it? I'm having similar issues and was trying to find the upgraded PN in SB M20-129 PN 950161 for the upgraded switch.
Mark Staggs Posted August 10 Report Posted August 10 Replying to this old thread because I think I'm having this exact problem after getting a pitot/static system cert done. I have a 1965 M20C that had the electric gear added months after being built in the spring of '65. Does anyone know where that Dukes 3203-00 switch can be bought or overhauled now-a-days?
redrider54 Posted August 13 Report Posted August 13 On 8/10/2025 at 3:02 PM, Mark Staggs said: Replying to this old thread because I think I'm having this exact problem after getting a pitot/static system cert done. I have a 1965 M20C that had the electric gear added months after being built in the spring of '65. Does anyone know where that Dukes 3203-00 switch can be bought or overhauled now-a-days? Haven't found anyone to overhaul them and the only replacement is sold by LASAR and as you can imagine it's more than a gold bar and sold out. https://lasar.com/switches/880013-505-v21614-safety-switch
