Flyingfisher Posted August 23, 2018 Report Posted August 23, 2018 (edited) Hi guys, I searched and while I can find many references to adjusting my voltage regulator, I haven't found any instructions to do so. Pictured is my voltage regulator, an Electrodelta vr415f out of my 74 F model. I see two pots for adjustment but am not sure which does which. Hoping someone more knowledgeable can fill me in. Edited August 23, 2018 by Flyingfisher Quote
Oldguy Posted August 23, 2018 Report Posted August 23, 2018 From lamartech.com/voltage-regulators.html. 1 Quote
orionflt Posted August 23, 2018 Report Posted August 23, 2018 The VR415 regulator is not meant to be adjusted in the field, it is a solid state regulator. the only adjustment info you will find in the manuals covers the older regulators. Brian 1 1 Quote
Flyingfisher Posted August 23, 2018 Author Report Posted August 23, 2018 Thanks guys, ended up just rewiring the field wire and using contact cleaner on everything and she's good as new for now. 2 Quote
markejackson02 Posted October 24, 2018 Report Posted October 24, 2018 I have a 1977 J (actually a 1976) which has a VR415F. Is there any way to adjust this that doesn't involve running the airplane full blast while I hang upside down under the panel? Quote
LANCECASPER Posted October 24, 2018 Report Posted October 24, 2018 58 minutes ago, markejackson02 said: I have a 1977 J (actually a 1976) which has a VR415F. Is there any way to adjust this that doesn't involve running the airplane full blast while I hang upside down under the panel? On 8/23/2018 at 12:21 PM, orionflt said: The VR415 regulator is not meant to be adjusted in the field, it is a solid state regulator. the only adjustment info you will find in the manuals covers the older regulators. Brian Quote
ArtVandelay Posted October 25, 2018 Report Posted October 25, 2018 I have a 1977 J (actually a 1976) which has a VR415F. Is there any way to adjust this that doesn't involve running the airplane full blast while I hang upside down under the panel? You need access to a variable voltage power supply. Quote
markejackson02 Posted October 31, 2018 Report Posted October 31, 2018 On 10/24/2018 at 4:28 PM, markejackson02 said: I have a 1977 J (actually a 1976) which has a VR415F. Is there any way to adjust this that doesn't involve running the airplane full blast while I hang upside down under the panel? I was able to adjust it per the service manual. I removed the right seat for easier access. Tied down/chocked, started plane, voltmeter on buss, 13.5 volts @ 2000 RPM. Adjusted to 14.2 volts @ 2000 RPM and 14.3 @ full throttle. It solved my strobe issue, my radio issue, and my battery issue. 3 Quote
carusoam Posted November 1, 2018 Report Posted November 1, 2018 Great details Marke! Thanks for sharing. Best regards, -a- Quote
