Hi,
I just got back my oil analysis. The lab says everything is ok, but would like to get a better feeling for the data. Does someone want to share data for the IO-360?
Thanks.
I have my latest one electronically.  Can you post or PM your email and I will send a copy?  Comparing them may not be as important as developing a trend.  Different labs can have different results, which is why it is important to not only do the analysis regularly, but to use the same lab as well.
Metals Last Average
ALUMINUM 4 4
CHROMIUM 4 5
IRON 23 28
COPPER 13 13
LEAD 4055 3252
TIN 3 1
MOLYBDENUM 0 0
NICKEL 2 4
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 1
BORON 0 0
SILICON 7 9
SODIUM 0 0
CALCIUM 1 4
MAGNESIUM 1 2
PHOSPHORUS 0 0
ZINC 1 2
BARIUM 0 0
Blackstone Oil Report. About 30 to 35 hours between oil changes. Factory overhaul engine with roller tappets, about 250 hrs so far. Aeroshell W100 (AD) oil.
Thank you for your data. Seems I have to much Copper. I'll try Camguard now and see how it develops.
Metals
ALUMINUM 5
CHROMIUM 2
IRON 33
COPPER 25
LEAD 4988
TIN 1
MOLYBDENUM 0
NICKEL 1
BORON 0
CALCIUM 5
MAGNESIUM 0
PHOSPHORUS 1115
ZINC 7
BARIUM 0
Can you get an analysis from Blackstone despite being located in Germany?  I am mechanically challenged; I am surprised I even figured out how to start my plane.  Blackstone gives a great narrative when they do an analysis.  Really breaks it down.
I am using Aeroshell 15W50. I used the oil for around 45hrs, I'll reduce that now to 25hrs. IMHO: Half the time in use, half the contamination?
Are you using AeroShell multigrade? I have read that it reacts with the copper flashing on the engine parts particularly the cam. If this is the case it's no big deal, but it does kind of obscure your true copper rating. If it were a bearing issue, you would have seen an up tic in tin and other metals as well as it would mean that the babbitt metal in the bearings was compromised...
Thanks for the info. The values were roughly the same for the last 3 years, so the Aeroshell explanation sounds good. Interestingly my lab always said everything is fine, and in the last report they said copper and steel a bit high but still within normal limits. It seems it depends on who is writing the report...
