meddesign Posted April 6, 2011 Report Posted April 6, 2011 Introducing PropPastie. This item was inspired by a discussion on the MAPA discussion board about how one should position the propeller in winter. Enjoy, and "off line" comments and encouragements would be appreciated. PropPastie.com Don B
carusoam Posted April 6, 2011 Report Posted April 6, 2011 Nice idea. [1] Want to keep water and sunshine out/off of the prop seal. [2] Need to keep water from collecting in the spinner. It inevitably freezes and causes an imbalance. There is always an argument on how best to park your prop... [1] Horizontal, people walk into it, or the pilot bumps his head on it while performing pre-fligt activities. [2] Vertical, birds land on the tip and leaving droppings that run down the length of it. I park mine at about a 15 degree angle off vertical. Water doesn't collect, birds can't land on it, modern seals are somewhat UV resistant and water tight. Can I get a cover for my fuel caps? It is hard to get them opened when they are full of ice..... Best regards, -a-
meddesign Posted April 6, 2011 Author Report Posted April 6, 2011 thanks, In winter a blade open on the bottom to drain any water to keep from freezing in the spinner, summer your way is good.
meddesign Posted April 6, 2011 Author Report Posted April 6, 2011 fuel cap, maybe my next prodoct thanks again
