Decided to run a report from one of my flights.  I requested two flights, and both came back with an NIC error.  I have a kt-74 connected to a 430W.  I plan to call the avionics shop and see what they say.  In the meantime, I was wondering if anyone had any input on the report.  Thanks
PAPR_20170721_A7EC50_43606669.pdf
On the subject of ADS-B, while my report doesn't contain any errors for the GDL-88 (other than a few air on ground), I have noticed that Flightaware is no longer tracking any of my flights. Any ideas why?
Tracking vs. displaying may be the issue...
The FA setting that is most confusing....
Show position only flights...
See if you have selected this or not?
It's definitely checked. See if you can find any ADS-B entries, N1161Z
Make sure kt-74 configured for air switch and logic is correctly set ..i.e. Going low vs high
  • 1 year later...
Just an update.  This actually got fixed when I took my plane in for the Aspen install.  They updated my 430W; he said I was a few versions behind.  It took care of the NIC error.
