xcrmckenna Posted March 17, 2017 Report Posted March 17, 2017 So this is my first owner problem. I have an 830 and want to do a data download to put it on Savvy but I can't get it to. When I hold down the LF And Step buttons for more than 5 seconds and get into the programming mode I scroll through to the Dump? N and when I press the LF button to switch to transfer the data to the flash drive, it does nothing. I've read the manual and read the instructions off Savvy. I'm not sure what I'm missing. Sent from my iPhone using Tapatalk
Bob_Belville Posted March 17, 2017 Report Posted March 17, 2017 I have a 930 so it might be different. I do not have to go into program mode. When I insert the USB drive into the 930 it automatically assumes I want to download data. It asks if I want to download new flights or download all flights.
Guitarmaster Posted March 17, 2017 Report Posted March 17, 2017 Yes. What Bob said. ^^^^^. The 900 is the same and I think the 830 is the same as the 900. In that respect anyway. Sent from my XT1585 using Tapatalk
xcrmckenna Posted March 17, 2017 Author Report Posted March 17, 2017 Maybe the USB flash drive I have is not compatible?Sent from my iPhone using Tapatalk
Browncbr1 Posted March 17, 2017 Report Posted March 17, 2017 for some reason, some usb drives don't work.. The one that came with the unit should work when you just insert it though... Another owner recently had the same problem as you... even though he reformatted the usb to fat32, it still didn't work... so, he used another usb drive and it worked ok..
ArtVandelay Posted March 17, 2017 Report Posted March 17, 2017 Maybe the USB flash drive I have is not compatible? What happens when you plug it in? Without going into program mode?It should ask if you want to dump new data, select yes...that's it. 1
xcrmckenna Posted March 17, 2017 Author Report Posted March 17, 2017 What happens when you plug it in? Without going into program mode?It should ask if you want to dump new data, select yes...that's it. It does nothing. Like it doesn't see it. I'm guessing it's not compatible?Sent from my iPhone using Tapatalk
Marauder Posted March 17, 2017 Report Posted March 17, 2017 It does nothing. Like it doesn't see it. I'm guessing it's not compatible?Sent from my iPhone using Tapatalk My USB thumb drive failed on my 830. Find another one and format it for FAT32 and make sure it is not larger than a 4Gb. Larger ones won't work.If after you do that and the drive still doesn't work, remove it, insert it again but wiggle it a little bit when it is in the port. It should automatically download. No digging into the menu should be required. Sent from my iPad using Tapatalk Pro 2
xcrmckenna Posted March 17, 2017 Author Report Posted March 17, 2017 My USB thumb drive failed on my 830. Find another one and format it for FAT32 and make sure it is not larger than a 4Gb. Larger ones won't work.If after you do that and the drive still doesn't work, remove it, insert it again but wiggle it a little bit when it is in the port. It should automatically download. No digging into the menu should be required. Sent from my iPad using Tapatalk Pro The one I got is a 16gb. I bet that is the problem. ThanksSent from my iPhone using Tapatalk 1
air cooled dad Posted March 20, 2017 Report Posted March 20, 2017 I'm having the same issue. Tried two different thumb drives. Post an update when you succeed. I will not be near my plane to try another thumb drive for a week.
Pritch Posted March 20, 2017 Report Posted March 20, 2017 I just plug the memory stick that came with my JPI 730 in and its ready to dump (all or new). Then plug it into my laptop and click on EzTrend2.exe. Pritch 1
xcrmckenna Posted March 20, 2017 Author Report Posted March 20, 2017 The seller didn't send the jpi thumb drive with the plane, I might call jpi and see if they will sell me one. It will be at least a week before I'm back at my plane as well. Sent from my iPhone using Tapatalk
carusoam Posted March 20, 2017 Report Posted March 20, 2017 (edited) Check the JPI website. It is probably one of their parts. Keep in mind they are not big G when it comes to these kind of things... https://www.jpinstruments.com/product-category/adapters-and-cables/ i didn't see the USB bits, but the other devices for downloading data from the older models is there... more details can be found in the user manual for your device. Also on line... Best regards, -a- Edited March 20, 2017 by carusoam
kortopates Posted March 20, 2017 Report Posted March 20, 2017 1 hour ago, Pritch said: I just plug the memory stick that came with my JPI 730 in and its ready to dump (all or new). Then plug it into my laptop and click on EzTrend2.exe. Pritch Pritch, you gotta try out www.savvyanalysis.com/ An account is free and it provides free archival of your data and the online tools blows away EzTrends plus its makes its easy to share your data with your maintenance professional or anyone you want - or keep it private. Of course I work for Savvy, so I am bit biased, but its all true. 5
Marauder Posted March 20, 2017 Report Posted March 20, 2017 Pritch, you gotta try out www.savvyanalysis.com/ An account is free and it provides free archival of your data and the online tools blows away EzTrends plus its makes its easy to share your data with your maintenance professional or anyone you want - or keep it private. Of course I work for Savvy, so I am bit biased, but its all true. So Paul, what's the scoop with Mike B sending out an email asking people to sign up for a Patreon to benefit his activities? Sent from my iPad using Tapatalk Pro 1
kortopates Posted March 20, 2017 Report Posted March 20, 2017 4 hours ago, Marauder said: So Paul, what's the scoop with Mike B sending out an email asking people to sign up for a Patreon to benefit his activities? Sent from my iPad using Tapatalk Pro Mike is looking for people to help sponsor him in writing his new book "Engines". As most know, all of his article writing, seminars, webinars, blogs etc that he does monthly for AOPA and EAA are done at his own expense including most if not all travel. He coming down to San Diego to present next month to present a Wings seminar to our local pilots and he does this sort of stuff all the time at his own expense. Given all he does with his income limited to Savvy Aviation services and his legal expert testimony I believe he is looking at the Patreon program as a means to back off on the legal expert testimony so that he can free up enough time to dedicate to getting his next book on Engines. Mike is a super busy guy, and it made getting his Manifesto book out a real challenge and expect his forthcoming Engines book is a much bigger project and hence the need for some relief to dedicate time too it. Unfortunately even if its a best seller among us GA pilots, we all know its not going to generate the kind of sales a book company would be able to grant Mike a sizable advance to write the book like a best seller novelist would get. Hence why he's looking for help. But I think you'll find this web page very helpful https://www.patreon.com/savvyaviator Already the support has been awesome in just the couple days since announcement.
ArtVandelay Posted March 21, 2017 Report Posted March 21, 2017 The one I got is a 16gb. I bet that is the problem. ThanksSent from my iPhone using Tapatalk My 16G works just fine, maybe depends on firmware version? 1
carusoam Posted March 21, 2017 Report Posted March 21, 2017 (edited) Paul, Can you set up a separate thread for the Mr. Bush book #2? I think, if I understand correctly, this would be a book that would benefit most people on MS. It looks like for a small amount of dollars, we get a copy of the first book...and for a few dollars more, a copy of the second book that is just being started... I like aviation books, I like Mr. Bush's writing... Best regards, -a- Edited March 21, 2017 by carusoam 1
xcrmckenna Posted March 21, 2017 Author Report Posted March 21, 2017 I formatted my USB drive and when I get back to the plane I will see if it that did it.Sent from my iPhone using Tapatalk
Pritch Posted March 21, 2017 Report Posted March 21, 2017 21 hours ago, kortopates said: Pritch, you gotta try out www.savvyanalysis.com/ An account is free and it provides free archival of your data and the online tools blows away EzTrends plus its makes its easy to share your data with your maintenance professional or anyone you want - or keep it private. Of course I work for Savvy, so I am bit biased, but its all true. Just joined, I do like it better, now I need to learn how to interpret the data. thanks Pritch
carusoam Posted March 21, 2017 Report Posted March 21, 2017 Consistent operations is the start of being able to interpret the data... every time you touch a knob, it is going to leave a foot print... Best regards, -a-
Marauder Posted March 21, 2017 Report Posted March 21, 2017 Mike is looking for people to help sponsor him in writing his new book "Engines". As most know, all of his article writing, seminars, webinars, blogs etc that he does monthly for AOPA and EAA are done at his own expense including most if not all travel. He coming down to San Diego to present next month to present a Wings seminar to our local pilots and he does this sort of stuff all the time at his own expense. Given all he does with his income limited to Savvy Aviation services and his legal expert testimony I believe he is looking at the Patreon program as a means to back off on the legal expert testimony so that he can free up enough time to dedicate to getting his next book on Engines. Mike is a super busy guy, and it made getting his Manifesto book out a real challenge and expect his forthcoming Engines book is a much bigger project and hence the need for some relief to dedicate time too it. Unfortunately even if its a best seller among us GA pilots, we all know its not going to generate the kind of sales a book company would be able to grant Mike a sizable advance to write the book like a best seller novelist would get. Hence why he's looking for help. But I think you'll find this web page very helpful https://www.patreon.com/savvyaviator Already the support has been awesome in just the couple days since announcement. Thanks for explaining this. Patreon is used for a lot of things, just figured a guy with an established career wouldn't be setting up a "fund me" site. Sent from my iPhone using Tapatalk Pro
Marauder Posted March 21, 2017 Report Posted March 21, 2017 My 16G works just fine, maybe depends on firmware version? The earlier versions of the 830 (like mine) wouldn't support anything more than a 4Gb drive. I remember hitting up all the Best Buy's in town looking for one since everything else was 8 or 16. Hope he gets it working. Sent from my iPhone using Tapatalk Pro
kortopates Posted March 21, 2017 Report Posted March 21, 2017 2 hours ago, Pritch said: Just joined, I do like it better, now I need to learn how to interpret the data. thanks Pritch Here is a great short article to show you the basics and get you started: https://www.savvyanalysis.com/articles/in-flight-diagnostics 2
xcrmckenna Posted March 24, 2017 Author Report Posted March 24, 2017 Well let's hope this works for me:) Sent from my iPhone using Tapatalk 1
