Drumstick Posted January 22, 2017 Report Posted January 22, 2017 Starting a new thread for this topic. I've seen the other posts but not all the hardware was covered. Most were replacing a broken arm - mine is missing -everything! So I can get the arm from a member but is there a bracket that is missing as well? The plastic pieces are from a newer M20c as it is molded for the newer style door arm.
carusoam Posted January 22, 2017 Report Posted January 22, 2017 (edited) Somebody machined a nice looking one from a block of aluminum around here... fuzzy memory... See if it was Chocks that made them? -a- Edited January 22, 2017 by carusoam
eman1200 Posted January 22, 2017 Report Posted January 22, 2017 Just now, carusoam said: Somebody machined a nice looking one from a block of aluminum around here... fuzzy memory... See if it was Chocks that made them? -a- @DrBill 1
carusoam Posted January 22, 2017 Report Posted January 22, 2017 https://mooneyspace.com/search/?&q=Baggage Door arm&item=21077 try this search result to see if it narrows things down... Best regards, -a-
Drumstick Posted January 22, 2017 Author Report Posted January 22, 2017 (edited) So I know I can buy the new arm but the arm attaches to brackets and also has screws. What kind of bracket and screws? Also - the interior seems different and has an upholstered panel and mine has the plastic for years the later model. Edited January 22, 2017 by Drumstick
DrBill Posted January 22, 2017 Report Posted January 22, 2017 Here is what I made, what else do you need ? 2
carusoam Posted January 22, 2017 Report Posted January 22, 2017 (edited) Eman, U R TheMan! (The power of memory is strong in this one) Best regards, -a- Then it turns out, I'm a minute behind Dr, Bill who is delivering the info directly! Edited January 22, 2017 by carusoam
Drumstick Posted January 22, 2017 Author Report Posted January 22, 2017 1 hour ago, DrBill said: Here is what I made, what else do you need ? I need the screws that hold the bracket to the door. It also looks like there is a bracket on the door that the arm screws into.
DrBill Posted January 22, 2017 Report Posted January 22, 2017 I'll go to the plane tomorrow and take some pictures and measurements. Bill
Drumstick Posted January 23, 2017 Author Report Posted January 23, 2017 57 minutes ago, DrBill said: I'll go to the plane tomorrow and take some pictures and measurements. Bill Much appreciated! The door plastics are definitely not original. I think there was supposed to be an upholstered panel like the one in your picture. Not sure if your bracket will fit wth the plastic stuff.
DrBill Posted January 23, 2017 Report Posted January 23, 2017 got tied up today will go tomorrow for sure
DrBill Posted January 24, 2017 Report Posted January 24, 2017 ok here is detail on my 65 m20e. both ends are held on with 8-32 riveted nutplate and 1/2 in SS 8-32 flat head screw and washer.. You can see rivets for nutplates in each picture. Bill
Drumstick Posted January 24, 2017 Author Report Posted January 24, 2017 Thanks! Perfect amount of detail that I needed. Anyone know where to find the piece of upholstery for the door? I don't think the plastic is compatible with this assembly which is probably why it was removed in the first place.
bucko Posted January 24, 2017 Report Posted January 24, 2017 Chocks made one for me that looks like the picture Drumstick has above. Email me for his contact info. 1
DrBill Posted January 24, 2017 Report Posted January 24, 2017 bucko is right he is doing them on a CNC Mill, and they come out nice. Reasonable price too if i remember right. his post is here somewhere, maybe in classifieds. bill
Drumstick Posted January 24, 2017 Author Report Posted January 24, 2017 1 hour ago, DrBill said: bucko is right he is doing them on a CNC Mill, and they come out nice. Reasonable price too if i remember right. his post is here somewhere, maybe in classifieds. bill Just ordered from Chocks. I will see if I can find the appropriate screw and washer.
Chocks Posted January 25, 2017 Report Posted January 25, 2017 Here:https://vimeo.com/201053455Sent from my iPhone using Tapatalk
carusoam Posted January 26, 2017 Report Posted January 26, 2017 (edited) Shane, You are the best! I like the option of the real part made from 3D printing! Nicely done, -a- Edited January 26, 2017 by carusoam 1
DrBill Posted March 1, 2017 Report Posted March 1, 2017 The original part is from sheet metal and is a POS since it bends so easily. The billett Al part is the way to go but so expensive for the factory. Bill
Chocks Posted March 1, 2017 Report Posted March 1, 2017 Shane, You are the best! I like the option of the real part made from 3D printing! Nicely done, -a- Thanks! I still want to test the printed one out some more, so metal only for now. But I think having the plastic option will be perfect for some users. Sent from my iPhone using Tapatalk 1
AH-1 Cobra Pilot Posted March 1, 2017 Report Posted March 1, 2017 1 hour ago, "Chocks" said: Thanks! I still want to test the printed one out some more, so metal only for now. But I think having the plastic option will be perfect for some users. What kind of printer/plastic did you use? I have a nylon and carbon-fiber, fiberglass, or Kevlar, (long strands, not chopped fibers), printer. The manufacturer claims that its CF parts are as strong as aluminum. If anyone has a file or at least dimensions, I can easily print these.
Ned Gravel Posted April 18, 2017 Report Posted April 18, 2017 Chocks still here? I am having trouble getting the Fedex number to work. Does it mean the part will not arrive?
gsxrpilot Posted April 18, 2017 Report Posted April 18, 2017 58 minutes ago, Ned Gravel said: Chocks still here? I am having trouble getting the Fedex number to work. Does it mean the part will not arrive? @"Chocks"
mike20papa Posted April 18, 2017 Report Posted April 18, 2017 I built a new one of these, but I remember the allowable space between the door edge and the fuselage opening was very limited (when closed). I had to use like .040" hinge blades and then it just barely fit. Used 4130 in order to get the stiffness required. The hinge pin/assembly has to be kept to an absolute minimum width. The best thing I did was get rid of that old rolled junk door hinge and replace it with an extruded 2024 hinge.
Chocks Posted April 18, 2017 Report Posted April 18, 2017 8 hours ago, Ned Gravel said: Chocks still here? I am having trouble getting the Fedex number to work. Does it mean the part will not arrive? Hey Flanders, I got your email and followed up with FedEx. I just sent you the details in your email. Sometimes Intl shipping gets a little screwy in my little town. 1
