ThorFlight Posted December 28, 2016 Report Posted December 28, 2016 Greetings everyone, So I’m planning to close on an ’81 J this Thursday and the nose gear truss was found to be dented during the pre-buy. Now the purchase price was adjusted accordingly and the plane's annual is due in January, so I’m going to flow right into that process with the same shop that did the pre-buy. The replacement part from Mooney is apparently ~$1500, which can be had in a couple of days. Sending in mine for repair at LASAR is about $750 + shipping (~$100), but it takes about 3 weeks for the turn-around (apparently they don’t have any refurbished ones available). Beyond the time and money differences, is there any other argument for one approach vs. the other? At this point, I’m leaning towards repairing it as I don’t have a pressing need to fly in January and wouldn’t mind putting $650 into my ADS-B nest egg. Thanks, and I'm looking forward to sharing my experiences with everyone and someday shedding my newbie status! Philip Quote
DonMuncy Posted December 28, 2016 Report Posted December 28, 2016 Definitely go with the LASAR rebuild. But no hurry. Don Maxwell says he has seen them with humongous dents and not giving any problem. 1 Quote
gsengle Posted December 28, 2016 Report Posted December 28, 2016 I have a very small dent, and wasn't planning to replace. Is there really any need?Sent from my iPhone using Tapatalk Quote
gsengle Posted December 28, 2016 Report Posted December 28, 2016 I will look into that thanksSent from my iPhone using Tapatalk Quote
DonMuncy Posted December 28, 2016 Report Posted December 28, 2016 Maxwell says that originally there was no limitation on the size dent. But someone pushed and pushed until the factory came up with the 1/32 inch limit. So, legally there is a definite downside, but no practical one; till you sell. Quote
gsengle Posted December 28, 2016 Report Posted December 28, 2016 1/32" basically means any dent is a problem :/Sent from my iPhone using Tapatalk Quote
kortopates Posted December 28, 2016 Report Posted December 28, 2016 The LASAR rebuild is better than new and really the better option.Sent from my iPhone using Tapatalk 2 Quote
DonMuncy Posted December 28, 2016 Report Posted December 28, 2016 LASARs rebuilt ones are beefed up, and have stops to help prevent damage. If someone really wants to, they can bend the stops. But still better than original. 1 Quote
ThorFlight Posted December 28, 2016 Author Report Posted December 28, 2016 1 minute ago, DonMuncy said: Maxwell says that originally there was no limitation on the size dent. But someone pushed and pushed until the factory came up with the 1/32 inch limit. So, legally there is a definite downside, but no practical one; till you sell. Wow! Yeah, I can't recall ever hear about a nose gear failure due to a "dented truss". Anyone have a recent report regarding the rubber tube fix preventing this in the future? Seems like a good idea. Quote
gsengle Posted December 28, 2016 Report Posted December 28, 2016 Mine got dented despite having the lasar stops :/Sent from my iPhone using Tapatalk Quote
ThorFlight Posted December 28, 2016 Author Report Posted December 28, 2016 Seems like LASAR is the winner. Good to know and thanks! Quote
DonMuncy Posted December 28, 2016 Report Posted December 28, 2016 My hangar elf designed and installed an alarm system that is activated when the limit is reached. It sounds a piezo while the limit is in contact, but you probably could not hear it over a running tug. Better, though, it activates a quieter piezo in the cabin, which remains on until re-set. When parked out of town, if I open the door and hear the alarm, I know to go check the truss for damage. 5 Quote
kortopates Posted December 28, 2016 Report Posted December 28, 2016 I am pretty sure the 1/32" stems from the 43.13.b data that allows up to 10% of wall thickness. Mooney could not exceed that. We see plenty of nose wheel trusses fail - presumably after being dented and ignored for sometime. But I don't have any first hand info on that but would not be ignoring it either. Why risk a $40k repair for less than a $1K?Sent from my iPhone using Tapatalk 3 Quote
Hector Posted December 28, 2016 Report Posted December 28, 2016 I have the Lasar strut with the stops. The stops need to be checked occasionally to make sure they are set right but it will prevent costly dents and it's a load off my mind when I travel and the FBO moves my plane. Sent from my iPad using Tapatalk Quote
slowflyin Posted December 29, 2016 Report Posted December 29, 2016 I have the Lasar strut with the stops. The stops need to be checked occasionally to make sure they are set right but it will prevent costly dents and it's a load off my mind when I travel and the FBO moves my plane. Sent from my iPad using Tapatalk +1, The stops give me more peace of mind as well. However, a tug will still break the stop off. But all in all, it is still a much better truss.Sent from my iPad using Tapatalk Quote
kevinw Posted December 29, 2016 Report Posted December 29, 2016 Always learning something new on MS. My first thought would've been OEM. Thanks for the info guys! Quote
mike_elliott Posted December 29, 2016 Report Posted December 29, 2016 On 12/27/2016 at 8:44 PM, DonMuncy said: My hangar elf designed and installed an alarm system that is activated when the limit is reached. It sounds a piezo while the limit is in contact, but you probably could not hear it over a running tug. Better, though, it activates a quieter piezo in the cabin, which remains on until re-set. When parked out of town, if I open the door and hear the alarm, I know to go check the truss for damage. Don, have your hanger elf contact me about this system! Quote
DonMuncy Posted December 30, 2016 Report Posted December 30, 2016 12 hours ago, mike_elliott said: Don, have your hanger elf contact me about this system! PM semt Quote
Richwilde Posted February 4, 2017 Report Posted February 4, 2017 Don, could you send me contact info for this system? Thanks 306-581-9830 richwilde@yahoo.com Quote
Chocks Posted February 5, 2017 Report Posted February 5, 2017 Do any of you have a link or images on what that damage looks like and/or what to look for?Sent from my iPhone using Tapatalk Quote
FBCK Posted February 5, 2017 Report Posted February 5, 2017 Is it possible to exceed the limits with the rudder peddle and directional brakes, it seem the turning radius can be pretty tight when turning in the plane. Quote
jclemens Posted February 5, 2017 Report Posted February 5, 2017 No, you need a tug to bend the nose truss. FYI- if you order a new one from Mooney you can get the one with stops. Quote
Andy95W Posted February 5, 2017 Report Posted February 5, 2017 2 hours ago, jclemens said: No, you need a tug to bend the nose truss. FYI- if you order a new one from Mooney you can get the one with stops. It's a lot cheaper to send your old one to LASAR. They have authorization to perform weld repairs and add the stops. 1 Quote
jclemens Posted February 6, 2017 Report Posted February 6, 2017 The last one I bought was about the same either way. One just took longer. Quote
XXX Posted March 15, 2017 Report Posted March 15, 2017 On 12/27/2016 at 9:03 PM, Hector said: I have the Lasar strut with the stops. The stops need to be checked occasionally to make sure they are set right but it will prevent costly dents and it's a load off my mind when I travel and the FBO moves my plane. Sent from my iPad using Tapatalk Hector, I just replaced my nose truss because the right stop was broken completely off. The truss was not dented but the broken weld had a pinhole that was leaking water (not sure how water got in). Going forward, I will only allow my plane to be tugged by the kind that supports the nose wheel. Every FBO I visit I always ask if they understand the turning limitations of the Mooney and every one of them has told me yes. Every time I preflight after visiting another airport, I feel the truss for dents but didn't think I needed to check the stops. Due to their location, it is difficult to see the stops without laying on the ground and using a flashlight. The universal tow bars (see pic) are designed for much larger aircraft and should never be used on a Mooney. I learned my lesson. Never again. 1 Quote
