Schinderhannes Posted December 24, 2016 Report Share Posted December 24, 2016 In the spirit of "bonus season" I have decides to do another panel update and will be removing the following radios: Garmin SL30 NAV/COM/Glideslope with monitor function for second COM and VOR complete with tray and connectors $2900 Garmin (Apollo) GX60 COM / GPS complete with tray, connectors, antenna and MD41 Annunciation Control Unit $2200 The radios are still installed in the aircraft and will be removed immediately after they are sold. I will post better pictures later. Garmin AT Apollo GX-60 offers all the capability of the GX-50 IFR Approach certified GPS, but it also adds a very sophisticated COMM transceiver.The COMM section in the GX-60 is a 760 channel radio with active / standby flip-flop. It is possible to listen to the standby frequency while the radio monitors the active frequency for any activity. This is almost like having two separate radios, because you can gather additional information on another frequency while making sure you are not missing a transmission.The COMM transceiver in the GX-60 offers a very respectable 8 watts minimum output (more than a KX-170B, for example). Many GPS/COMM radios are less powerful than a dedicated COMM or the COMM section of a NAV/COMM, but that is not the case with the GX-60.The GX-60 operates with 14-28 volts input. The COMM section of a GPS/COMM often restricts the whole radio to 14 volt operation (or requires the use of a voltage converter). The GX-60 avoids the cost, heat, weight, complexity, and potential failure point of a voltage converter in a 28 volt aircraft.Additional COMM features include: Transmit indication Stuck microphone timeout (35 seconds) National Weather Service channels Internal two-place voice activated intercom Frequency memory - from GPS database, last 10 used, user storage, weather, and emergency (121.50 MHz) Two microphone inputs 12 watt audio amplifier for cabin speaker Regarding its GPS features, the Apollo GX-60 offers an IFR non-precision approach certified GPS Receiver loaded with features, including a high-definition moving map display on a large sunlight viewable screen. The aircraft's position relative to airports, runways, VORs, NDBs, intersections, and special use airspace can be easily seen on the moving map. Operation is streamlined and pilot workload reduced through the use of Smart Keys and an intuitive interface. Airspace and navaids can be added or deleted from the map with a single press of the button. Bright, clear electroluminescent display - This display measures 160 pixels wide by 80 pixels high, and its brightness is controlled automatically to match lighting conditions. This display can be set up to show a moving map, navigation information, and a graphical CDI. Moving Map graphics - The map shows your aircraft's position relative to surrounding database items. This map may be configured to use the full screen, or only part of it. In Full-screen mode, most of the display will show the map, but the corners are used to show the TO waypoint, bearing, distance, and map scale. In Split-screen mode, the display will also show ground speed, track, and cross track error. The map may be oriented with track up, desired track up, or magnetic north up. Map objects may be selected for information or "Direct To" navigation. Ease of use - The GX-60 uses Smart Keys to put the most commonly used features for a given operation right in front of the pilot. The Smart Key buttons are labeled right on the display. This makes it easy to access the GX-60's power, without crowding the faceplate with buttons. Simple navigation is available right away with the "Direct To" function. There is built-in simulation software for learning the rest of the features when you are safely on the ground, and can devote your full attention to training. Pilot-focused design - It is clear that this GPS was designed by pilots. A full complement of E-6B calculations are available. The GX-60 can receive altitude from encoder, and it knows the minimum safe altitude and enroute safe altitude for your flight. The navigation pages are user definable and have auto sequencing. The pilot may store up to 30 flight plans of 20 legs each, and these flights are flown with automatic waypoint sequencing. Up to 500 pilot defined waypoints may be added to the database. Automatic magnetic variation is based on your current position. The navigation computer has the ability to set up a parallel track offset. This unit also has both a countdown timer and a flight timer. Peace of mind - An Emergency Search function quickly displays the 20 nearest airports (other waypoint types are available as well). Even better, the pilot may set search criteria based on runway length, surface, and lighting. With search criteria, time isn't spent deciding about airports that can't be used. The GX-60 may also perform this search around any waypoint. This is useful to know what other airports are available near your destination. Datacard database - The GX-60 database stores comprehensive airport and navaid information. These database cards are front loading, which makes it much easier to keep the data up-to-date. Compatibility - The Apollo GX-60 may be interfaced with an HSI, CDI, Autopilot, Blind Encoder, Fuel Sensor, and external Moving Maps. Two RS-232 ports are provided. 1 Quote Link to comment Share on other sites More sharing options...
Schinderhannes Posted January 3, 2017 Author Report Share Posted January 3, 2017 Price update & more pictures. SL30 $2800 GX60 & MD41 $1950 1 Quote Link to comment Share on other sites More sharing options...
Dick Burton Posted January 24, 2017 Report Share Posted January 24, 2017 Do you still have the Gx60? I'd like to buy it.my name is Dick Burton 816-405-6688 I'm a new pilot and it would be a good upgrade for my plane,thanks. Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 24, 2017 Report Share Posted January 24, 2017 (edited) hey Dick Burton, You might want to send a private message (PM) to 9495V. To do this, click on his doggy avatar and find the send a message option. I'm not very technical either, but I have managed to send a PM or two... Good luck and Best regard, -a- Edited January 24, 2017 by carusoam 1 Quote Link to comment Share on other sites More sharing options...
Schinderhannes Posted January 24, 2017 Author Report Share Posted January 24, 2017 (edited) The GX60 is sold - SL30 still available. Just realized I didn't answer the question regarding Chica's age. She just turned 8 and flies since she is 6 weeks old. Her flying career started sleeping in the strakes of a Long Ez. She still likes to sleep during cruise, but at 6.5 lbs fully grown she doesn't understand all the talk about short bodies being too small. Edited January 24, 2017 by N9495V Answered dog question 1 Quote Link to comment Share on other sites More sharing options...
IvanP Posted January 31, 2017 Report Share Posted January 31, 2017 Good afternoon, If the SL 30 is still available, please drop me an e-mail at ipetrzelka@charter.net . Thanks, Ivan Quote Link to comment Share on other sites More sharing options...
glbtrottr Posted February 2, 2017 Report Share Posted February 2, 2017 I'll take both per your offer - thank you! Quote Link to comment Share on other sites More sharing options...
