SPEEDMOONEY Posted August 10, 2016 Report Posted August 10, 2016 I'm looking for the electric engine for cowl flaps for a 1991 M20J. Pn: 880050-501 X1 Moteur assy geared. Any idea ?
Guest Posted August 11, 2016 Report Posted August 11, 2016 On August 10, 2016 at 10:56 AM, SPEEDMOONEY said: I'm looking for the electric engine for cowl flaps for a 1991 M20J. Pn: 880050-501 X1 Moteur assy geared. Any idea ? What seems to be wrong with yours? Clarence
Awful_Charlie Posted August 11, 2016 Report Posted August 11, 2016 What's wrong with going to Mooney? They can replace it with the improved 940070-503 at the same time!
SPEEDMOONEY Posted August 12, 2016 Author Report Posted August 12, 2016 pending at least 12 weeks and 1500 USD !!!
SPEEDMOONEY Posted August 12, 2016 Author Report Posted August 12, 2016 working perfectly 10 times or so then not working at all x times then working .....
kortopates Posted August 12, 2016 Report Posted August 12, 2016 Use the search function. This has been covered. You can send it in the OEM who will rebuild in about a week and at a great savings - you'll get the current production version too. The company's name is Globe motors. Sent from my iPhone using Tapatalk
Andresen Posted October 21, 2022 Report Posted October 21, 2022 I replaced that little motor with one,from a normal dealer for,e-motors, works fine
Fly Boomer Posted October 21, 2022 Report Posted October 21, 2022 13 hours ago, Andresen said: I replaced that little motor with one,from a normal dealer for,e-motors, works fine Got a reference to the vendor of that motor? Might be handy to just replace it if there is a suitable replacement.
Philip France 13 Posted October 21, 2022 Report Posted October 21, 2022 You can get it. Overhauled for reasonable price by globe atlanta 1
PierreL Posted November 9, 2024 Report Posted November 9, 2024 Hello, I got a Mooney M20J with a cowl flap motor unserviceable. Where did you get it overhauled? Pierre
Fly Boomer Posted November 9, 2024 Report Posted November 9, 2024 1 hour ago, PierreL said: Hello, I got a Mooney M20J with a cowl flap motor unserviceable. Where did you get it overhauled? Pierre This thread goes back years but, if they are still doing it, Globe would be a good choice -- they likely manufactured the motor.
Fix Posted November 13, 2024 Report Posted November 13, 2024 On 11/9/2024 at 8:38 PM, PierreL said: Hello, I got a Mooney M20J with a cowl flap motor unserviceable. Where did you get it overhauled? Pierre Have you tried to connect 24v to the motor directly and tested it ?
kortopates Posted November 14, 2024 Report Posted November 14, 2024 You want to send it to Bobbie Eldridge at Globe in AL. The “repair” will be a new motor to the current new production Mooney spec with the next size up roller pins which will help longevity. Much cheaper than new from Mooney even though that’s exactly what you’ll be getting. Here is an older thread with more info, if it doesn't have contact info there are at least a half dozen threads on this topic to find it. Bobby is at BEldridge@globemotors.com 1
jetdriven Posted November 14, 2024 Report Posted November 14, 2024 They have two versions, a 1 Rpm and a 2 Rpm version. If you buy the 2 Rpm version it’s going to be 1300 bucks, and then when you find out that the airflow pushes the cowl flaps open in cruise then you get to buy the 1 Rpm version and pay another 1300 bucks because the first one is not returnable. 1
