roundout Posted November 12, 2010 Report Posted November 12, 2010 Quote: rbharvey Add me to the list of people who would like some clarification on this point--I suspect it's incorrect, but I'd like to hear some explanation of why you believe it to be the case.
rbharvey Posted November 12, 2010 Report Posted November 12, 2010 Out of the TCM, manual "....TSIO-550G engine models above 22,000 ft, do not lean beyond 1675F..". Very ambiguous, does that mean you cant do a "find the peak operation" for you will surely go above 1675, so you have to stay ROP, or does that mean all ROP/LOP operations need to be below 1675...who knows. I m pretty sure there are no Economy Cruise tables (LOP) above 22k in the POH
roundout Posted November 12, 2010 Report Posted November 12, 2010 Straight from the POH: Above 30.5 inHg of manifold pressure only full rich mixture is permitted. At altitudes above 22,000 feet, power settings above 2300 RPM must be operated at 1675o F TIT or richer. The best economy charts top out at FL220. It's interesting that the POH and the TCM manual use different verbiage to describe the same thing. You'd think it would be a CYA for Mooney POH to use the exact same language as the TCM manual.
