rocketman Posted November 30, 2015 Report Posted November 30, 2015 I just received my factory rebuilt TI-540-AF1B for my 1993 Bravo. After taking the old engine off my mechanic discovered that there are two air ducts that needed to be replaced that goes from the front of the cowling to the intercooler. The part numbers are 880102-001 and 650256-001. Anyone know who might be parting out a Bravo?
moxfox Posted December 1, 2015 Report Posted December 1, 2015 I replaced both of the same ducts on my Bravo, they are expensive! The intercooler duct alone is $441.90 !! The other is about half of that or a little more . There ought to be a law !!! Mooney has them , got them through Lake Aero styling in Clear lake Ca. PH 707-263-0412 asks for Dave in parts. Be prepared to wait though and you might have a bug them several times . Good luck! Hey it's only money though we got to go fast right !!!!
rocketman Posted December 1, 2015 Author Report Posted December 1, 2015 Not available from any MSC including LASAR. Mooney will have to make these meaning $$$ and time.
Piloto Posted December 2, 2015 Report Posted December 2, 2015 Can you post a picture of the duct. Mooney is not in the business of making air ducts. José
Bravoman Posted December 2, 2015 Report Posted December 2, 2015 Just out of curiosity, were the ducts shot in terms of condition thus requiring replacement or do they have to be replaced as a matter of course when the engine is replaced?
rocketman Posted December 5, 2015 Author Report Posted December 5, 2015 don't have pictures since the engine is being replaced in another area of the country but will get my mechanic to send me a picture. It is not routinely replaced on engine exchange. Mooney says this will take up to 2 months to make from their distributors. Anyone know who makes these parts? My plane is AOG and I can't believe it would take this long
carusoam Posted December 5, 2015 Report Posted December 5, 2015 Is it ordinary dimensions like a 2" round tube? Owner supplied parts could be a possible route while you wait for the real ones...(?) Automotive TC hoses come to mind. Silicone for high temp and fiber reinforced for pressure. To be clear, I am not making or even capable of making a recommendation here. Trying to bring up ideas that can be brought to your mechanic. Best regards, -a-
Piloto Posted December 5, 2015 Report Posted December 5, 2015 Most air ducts are just SCAT hoses. Check http://www.aircraftspruce.com/search/search.php?s=SCAT+DUCTING&x=26&y=14 José
Tony Armour Posted December 5, 2015 Report Posted December 5, 2015 I thought I had a pic but nada. Picture the orange flex air duct material (silicone feeling) except this is rectangle in size...something like 6"x10" and accordion so it can collapse and expand a little. I would get similar material and use silicone sealant to make patches on any holes at least to not be AOG.
LANCECASPER Posted December 6, 2015 Report Posted December 6, 2015 On November 30, 2015 at 2:36:04 PM, rocketman said: The part numbers are 880102-001 and 650256-001. In the parts catalog I can't find 880102-001, but 650256-001 is part number 26 on the attached pdf, so normal scat won't do it for this part. Maybe it could be repaired. DUCT M20M .pdf duct page 1.pdf duct page 2.pdf duct page 3.pdf
KSMooniac Posted December 6, 2015 Report Posted December 6, 2015 Definitely check out the specs on the original one and see if you can get some common SCAT to replace it. Sometimes the easy stuff will have a Mooney P/N, and if you can find the drawing it will be a simple SCAT tube with a dimension. DISCLAIMER: I have no direct knowledge of the Bravo configuration
Piloto Posted December 6, 2015 Report Posted December 6, 2015 Check with Home Depot, they have everything. José
rocketman Posted December 15, 2015 Author Report Posted December 15, 2015 Still dealing with these parts. Nobody seems to have them anywhere. No simple fix. The scat or scet or whatever the material is has a rectangular form in the middle to fit in the cowling. My mechanic can fix it but buying a used replacement seems easier. Does anyone know of any Bravo being parted out?
Dream to fly Posted July 8, 2017 Report Posted July 8, 2017 I wonder if Flexicraft in Chicago can make one to fit. They make flex couplers out of all sorts of material and high heat applications too.
thinwing Posted August 31, 2017 Report Posted August 31, 2017 The part is mfd of std 6 " orange scat tubing...with about 15 in placed in a vise to form a rectangular section to pass under intercooler intake 1
