flyingvee201 Posted November 15, 2015 Author Report Posted November 15, 2015 20 minutes ago, mike_elliott said: easily done, mine were a bit more complicated than the average vintage Mooney as I had a PTT, and the STEC AP controls on the pilot yoke which had to be desoldered and resoldered when put back on. I did too. Had the stec alt and a/p disconnect as well as the PTT
HRM Posted November 15, 2015 Report Posted November 15, 2015 1 hour ago, mike_elliott said: easily done, mine were a bit more complicated than the average vintage Mooney as I had a PTT, and the STEC AP controls on the pilot yoke which had to be desoldered and resoldered when put back on. OK, from the PM I am seeing a bolt, washer, nut and set screw. So you just pull those out and the yoke pops off?
47U Posted November 15, 2015 Report Posted November 15, 2015 I think some installations use a tapered pin instead of the 10/32 bolt. If the AD to inspect for cracks in the yoke shaft apply to your model, you might look in your logs and see if you're close to being due. It's every 500 hrs, I think. 1
mike_elliott Posted November 15, 2015 Report Posted November 15, 2015 1 hour ago, HRM said: OK, from the PM I am seeing a bolt, washer, nut and set screw. So you just pull those out and the yoke pops off? My F had the SB done on the pilots yoke, 2 bolts on the reinforced sleeve to remove and it comes off easily once the electronics are disconnected. The copilot side was a tapered pin. Back the nut off about 3 or 4 turns and smack it with a tapping tool, the pin will unseat, then you can remove the nut the rest of the way. Once out, the yoke is easily removed. Loosen the set screw also.
PTK Posted November 16, 2015 Report Posted November 16, 2015 One word of caution about the set screw underneath. It's in there very tight and needs a high quality allen wrench to get it out. Otherwise the head recess will strip or the wrench will twist! When putting it back make sure you put the appropriate torque wrench on it! That little screw has a torque value but it escapes me right now.
isaacpr7 Posted November 21, 2015 Report Posted November 21, 2015 On 11/14/2015 5:48:00, PTK said: I think your leatherwork looks great 47U! Sometimes less is more and I think it's perfect! I was playing with mine while watching the World Cup and came up with these. I was debating between powder coating or leather. Had some Spinneybeck leather left over from when I did the interior so decided to use it for the yokes. WOW!!! It looks amazing! Any chance that you may have the process for doing this anywhere in this forum? I tried once and failed miserably :(
DonMuncy Posted November 21, 2015 Report Posted November 21, 2015 I did my own in leather and I like them. But PTK's are much nicer.
isaacpr7 Posted November 22, 2015 Report Posted November 22, 2015 35 minutes ago, PTK said: Where are you located Isaac? I am based out of KCKV but I am currently deployed in Afghanistan. Two more months on this nine month deployment before I get to fly for pleasure once again ;) 3
Andy95W Posted November 23, 2015 Report Posted November 23, 2015 Based out of KCKV, you must be either 101st Airborne or 160th Night Stalker. Either way, be safe.
PTK Posted November 23, 2015 Report Posted November 23, 2015 14 hours ago, isaacpr7 said: I am based out of KCKV but I am currently deployed in Afghanistan. Two more months on this nine month deployment before I get to fly for pleasure once again ;) Thank you for your service Sir. Come back home safe. 2
isaacpr7 Posted November 23, 2015 Report Posted November 23, 2015 6 hours ago, N1395W said: Based out of KCKV, you must be either 101st Airborne or 160th Night Stalker. Either way, be safe. 101st (Air Assault) 1
Chocks Posted November 23, 2015 Report Posted November 23, 2015 We started doing customized yokes and panels about a year ago. I never thought it would become so popular. The powder coating and leather wrap jobs you guys did, look great! If you are interested in having your yoke done, here are some examples of the things we can do. Anything from solid glossy to flat gunmetal like the one's posted, we can do. 2
HRM Posted November 23, 2015 Report Posted November 23, 2015 6 minutes ago, FlyingSchmidt said: We started doing customized yokes and panels about a year ago. I never thought it would become so popular. The powder coating and leather wrap jobs you guys did, look great! If you are interested in having your yoke done, here are some examples of the things we can do. Anything from solid glossy to flat gunmetal like the one's posted, we can do. Those look great. When you remove the original plastic coating from the yokes or door handle, you are left with what looks like sintered aluminum. I sprayed my door handle with metal paint and then a clear coat and have been very happy with the result. I am thinking about doing it to the yokes and just putting some sort of heat shrink sleeve on the horns.
Chocks Posted November 23, 2015 Report Posted November 23, 2015 18 minutes ago, HRM said: Those look great. When you remove the original plastic coating from the yokes or door handle, you are left with what looks like sintered aluminum. I sprayed my door handle with metal paint and then a clear coat and have been very happy with the result. I am thinking about doing it to the yokes and just putting some sort of heat shrink sleeve on the horns. Are you sure it's a plastic coating? The yokes and handles are usually anodized aluminum. It might look like plastic because of the color dye but I can't tell from the pics. If it's anodizing, you don't want to remove that permanently, because it's what keeps your yoke and handles from corroding.
HRM Posted November 23, 2015 Report Posted November 23, 2015 1 hour ago, FlyingSchmidt said: Are you sure it's a plastic coating? The yokes and handles are usually anodized aluminum. It might look like plastic because of the color dye but I can't tell from the pics. If it's anodizing, you don't want to remove that permanently, because it's what keeps your yoke and handles from corroding. Pretty sure it's plastic and absolutely sure it isn't anodizing. It looks like they dipped the yokes into something not unlike Plasti-Dip, but a compound that hardens. After 50 years it starts to peel and crack. Not that difficult to clean off. Below is a close-up of the yoke horn showing this. The coating was fairly thick. 1
Chocks Posted November 23, 2015 Report Posted November 23, 2015 3 hours ago, HRM said: Pretty sure it's plastic and absolutely sure it isn't anodizing. It looks like they dipped the yokes into something not unlike Plasti-Dip, but a compound that hardens. After 50 years it starts to peel and crack. Not that difficult to clean off. Below is a close-up of the yoke horn showing this. The coating was fairly thick. Oh ya! Well hopefully you were able to smooth out a lot of the pocking from the sintering. If not, I've got some tricks that might work for you.
HRM Posted November 23, 2015 Report Posted November 23, 2015 39 minutes ago, FlyingSchmidt said: Oh ya! Well hopefully you were able to smooth out a lot of the pocking from the sintering. If not, I've got some tricks that might work for you. Where are you in Bat City? I'm headed up there for Thanksgiving.
Chocks Posted November 25, 2015 Report Posted November 25, 2015 On 11/23/2015, 1:52:52, HRM said: Where are you in Bat City? I'm headed up there for Thanksgiving. I'm right between S. Austin and Buda. I'm out of town for the holidays though. How long are you here?
