Guitarmaster Posted September 2, 2015 Report Posted September 2, 2015 This was not my idea. I got it off Don Maxwell's website, I thought it was a great idea so I tried it and I wanted to pass it on here. If your fuel caps are tough to get off, drop a few drops of oil from the dipstick on the shaft. It frees up those caps really nicely! No more busted fingers trying to get the caps open! 1
RobertGary1 Posted September 2, 2015 Report Posted September 2, 2015 The caps should be disassembled at each annual, the little internal seal replaced and the mechanism lubricated. This should avoid not only water entering but also sticky shaft problems between annuals. -Robert
Yetti Posted September 2, 2015 Report Posted September 2, 2015 qty 2 010 orings per side. take them apart and get the corrosion and gunk out of them. Adjust them to properly open and close
MyNameIsNobody Posted September 2, 2015 Report Posted September 2, 2015 Nothing, I repeat NOTHING is worse than a sticky shaft. Lubricate people, LUBRICATE... 3
Guitarmaster Posted September 4, 2015 Author Report Posted September 4, 2015 Nothing, I repeat NOTHING is worse than a sticky shaft. Lubricate people, LUBRICATE... Bahahahaha!!! ROFL!! nice...
HRM Posted September 6, 2015 Report Posted September 6, 2015 Nothing, I repeat NOTHING is worse than a sticky shaft. Lubricate people, LUBRICATE... The sexual innuendos associated with Mooney airplanes is limitless and never ceases to amaze 3
