721lp Posted September 14, 2010 Report Posted September 14, 2010 Has anyone converted their beacon (belly) to LED? If so, what kind, and are you pleased with the results. I have put the LED nav. LED bulbs in and they are amazing. Also added the LED overhead LED's, with equally good results. Next is the belly strobe. Sometimes it works, and sometimes it seems to "miss" a beat. Just curious about the LED beacons out there. I know they aren't cheap........
Mooney_Allegro Posted September 16, 2010 Report Posted September 16, 2010 Hello 721lp, where did you get the overhead reading light LED's? I'd love to add them to my aircraft. It it just a plug and play application?
721lp Posted September 17, 2010 Author Report Posted September 17, 2010 Here's the link for the over head lights. I also added the Fenix diffusers....makes for a really uniform light all across the panel. http://www.boyercreative.com/mooneypics/ShoulderLites/ShoulderLightsAd.pdf http://www.fenixgear.com/flashlight/Fenix_HeadLamp_Diffuser.html#catalog/img/5000-x0042.jpg Makes a great night combo. Also, my vertical card compass and audio panel had incandescents in series, so the LED's dim perfectly.
mjc Posted September 17, 2010 Report Posted September 17, 2010 Quote: 721lp Here's the link for the over head lights. I also added the Fenix diffusers....makes for a really uniform light all across the panel. http://www.boyercreative.com/mooneypics/ShoulderLites/ShoulderLightsAd.pdf
721lp Posted September 19, 2010 Author Report Posted September 19, 2010 I had to trim some plastic from the overhead.......but it was definitely worth it...The left light actually lights the Right part of the panel and the right light lights the Left part....but all's nice. I combined this with the under glareshield white lite from Spruce and I have MORE than enough light.
