I am considering purchase of a 1991 M20M Bravo.  Does anyone know a good service shop in the area of Ft Lauderdale to perform this work?  They have also offered to fly to Columbus, Ga area as well if I wanted that.  Who in this area would be recommended?
In my experiences, you'll be better served, and save money by contacting Phil (PJ) in Avon Park. He is a long time Mooney mechanic and owner. He knows them really well, and he will come to you.
Give him a call: (863) 873-9999
I highly recommend you contact Dan at DLK Aviation, at KRYY. He knows Mooney and a real honest gentleman
Call Dan at:  (770) 427-4954
Kennesaw, GA isn't quite in the area of Ft. Lauderdale as was requested. :rolleyes:
Must be a faulty Garmin GPS.... ;)
Premier is an authorized serve center. They will be expensive but thorough .
Make sure they haven't worked on the plane before.
Daytona has a MSC, they're probably cheaper than Premier
Gary, my GPS is perfectly fine but thank you!
It is a Garmin you know! The best there is!
But you clearly missed the op mentioned GA.
I bought my plane Via Premier as  brokers and they did the inspection. This is usually a No No but it worked out well.   I highly recommend them.
