Bendix/King KCS55A system up for sale. It is in great condition with no issues. Everything was working great when removed for a Garmin upgrade. The HSI has glideslope damping and bootstrap heading synchro.
KI-525a HSI PN 066-3046-07, SN 84659
KG-102a PN 060-0015-00, SN 39779
KMT-112 Flux Detector PN 071-1052-00, SN 50598
KA-51B Slaving Switch PN 071-1242-06, SN 24273
Price: $1500
  • 3 months later...
Andy, this is a nice high serial number system at a really good price for the buyer.  I have some new and used connectors and install parts if you need anything.  Don
  • 3 weeks later...
Hi Andy, I'm interested in the KCS-55A system let me know what's the next step, where are you located?.You can reach me at Hernan@durangohomerepair.com or my cell (336) 601 0879. Thank you
Hernan
Alan, thank you for information, I'm a fairly new mooney owner and still trying to learn as much as I can about my bird. Thank you again.
Hernan have you consulted an avionics installer and looked into the costs and what's involved to install in your plane?
Herman , The install costs will be about 40 hours labor , also if you don't have a GNS430 or a KX165  or SL30 you will need to buy a KN72 nav converter ....also plan on spending about 400 to 600 for a bench check.....best to talk to the installing tech for more input...
Herman, for installation figure more like 60 hours min. With connectors, harnesses and checks you can estimate approx. 6500$ min. to install. Those connectors aren't cheap.
The price is very good. Just iron down your install costs.
Connectors can be scrounged-up, but making and installing the harness is time consuming.  It is a good opportunity for sweat equity, though, if the buyer is so inclined and has a shop that will work with him.
I think I still have some of the connectors for such a system, as well as the mounting trays/brackets for the remote gyro and flux gate.
I have all of the connectors and the mount for the gyro , you can have everything for 200.00 that will be 6 connectors , and a mount with the new style isolators....
As I said before, that is a real sweet price for a high serial number like this one.  Here's what a harness for it would look like - you can see there is a large quantity of wire that needs to be routed from the panel to the rear avionics bay (gyro), and from the panel and rear avionics to the wingtip (fluxgate).
That is intimidating!
10 years ago I would have given my eye teeth to get this system for this price. But with Aspen systems and such it seems like a bit of a dinosaur.
It would be a good deal for a spare if you have one installed.
