I recently had my fuel pump complied with for an past AD (see attached) that prior shops had missed but Poplar Grove found during my recent crankshaft replacement.  Now all back together, my fuel pressure from the engine driven fuel pump is around 18-20 psi (in the yellow).  When I engage the boost pump, fuel pressure shoots up to ~45 psi (correct per mooney service manual).  Does anyone have any information on how to adjust this fuel pump to at least get me into the mid-green level (35-40 psi)?  What pressure readings are you guys seeing from the engine driven fuel pump?
Thanks,
Bill G
'91 M20M TLS Bravo
KHFY
Lear Romec Fuel Pump 2013_03_27_10_52_22.pdf
I suggested Josh, my A&P, give Don a call along with Bob @ Lear Romec.  Curious what others see as typical range without boost pump though.
