ChristianGodin Posted August 18, 2013 Report Share Posted August 18, 2013 I read the following somewhere written but an avionic shop owner: "In my humble opinion, the KFC-150 is a piece of junk. This system is full of monitors but the problem is that the monitor system often fail. It's prone to problems. The KFC-150 is a safe autopilot it just fails often and is expensive to keep up and running. The king KFC-200 and KAP-200 are older system but much more reliable autopilot." Anyone have any comments about that since a lot of Mooney are equiped with KFC-150? Quote Link to comment Share on other sites More sharing options...
Bennett Posted August 18, 2013 Report Share Posted August 18, 2013 The KAP 150 itself has been as reliable as my former KFC 200. My AP problems came from a failed AI, and in both cases, the pitch servo. When I had my recent AP problem solved by LAC Avionics, we had the KAP 150 sent back to Honeywell it be checked, and they "fine tuned" and reprogrammed a chip or two, but the KAP 150 was basically OK. Now the combination of rebuilt AI, a new pitch servo, a tuned KAP 150 is awesome. I have a SAM Icarus, for GPSS steering, following flight plans programmed into a GTN 750. Can't ask for better combination Quote Link to comment Share on other sites More sharing options...
FAST FLIGHT OPTIONS LLC Posted August 18, 2013 Report Share Posted August 18, 2013 I have the KFC 200 which has proven rock solid. I had autopilots central overhaul the roll servo last annual. Other then that minor discrepancy it gets 5 stars for ease of use and reliability. Quote Link to comment Share on other sites More sharing options...
jackn Posted August 18, 2013 Report Share Posted August 18, 2013 3 1/2 years ago, when I first bought my plane, it had an intermittant problem with the KFC150. I brought it to my local avionics shop. 3 month later and a lot of money the avionics shop told me the same thing(poor A/P). We then found it was a bad AI, that fixed the problem. Last year I started having another intermittant problem, this time I took it to Griffin Avionics in Hyannnis MA. They specialize in A/Ps. They told me the KFC150 is a very good A/P. They found and fixed 3 problems in 1 1/2 days(HSI, + 2 connector issues). Again, nothing wrong with the A/P. A/P problems are usually intermittant and very hard to trouble shoot in the shop unless you have the proper test equipment and experience. This can lead to a very frustrated tech as well as owner. i suggest you call auto pilot central and ask their opinion. Now it's steady as a rock and highly capable, especially when connected to GPSS and Alt pre-select. Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted August 18, 2013 Report Share Posted August 18, 2013 The KAP 150 itself has been as reliable as my former KFC 200. My AP problems came from a failed AI, and in both cases, the pitch servo. When I had my recent AP problem solved by LAC Avionics, we had the KAP 150 sent back to Honeywell it be checked, and they "fine tuned" and reprogrammed a chip or two, but the KAP 150 was basically OK. Now the combination of rebuilt AI, a new pitch servo, a tuned KAP 150 is awesome. I have a SAM Icarus, for GPSS steering, following flight plans programmed into a GTN 750. Can't ask for better combination  Same here, KAP 150 has been totally trouble free. Recent runaway trim issue was the thumb switch. Quote Link to comment Share on other sites More sharing options...
Jsavage3 Posted August 27, 2013 Report Share Posted August 27, 2013 KAP 100 AP here and looking to upgrade -- I need altitude hold at a minimum. Â Any recommendations? Â STEC 30ALT for just altitude...or...60PSS for alt hold and vertical modes... Â Might there be any other options? Quote Link to comment Share on other sites More sharing options...
jetdriven Posted August 27, 2013 Report Share Posted August 27, 2013 We have the 30 ALT and it is nice, push the button, hold altitude. Trouble free for, according to the records, 12 years. But it is a lot of money for a button, a box the size of a pack of cigarettes, a pressure transducer, and a servo. Quote Link to comment Share on other sites More sharing options...
BorealOne Posted August 27, 2013 Report Share Posted August 27, 2013 I agree that a KFC-150 is expensive to keep up and running, but while running it is rock solid. Kitchener Avionics (arguably the 'go-to' shop in E. Canada) says that you should budget for AI and servo overhauls every 500h, and my experience bears that out. Quote Link to comment Share on other sites More sharing options...
David Mazer Posted August 27, 2013 Report Share Posted August 27, 2013 I spent a ton of money on my KFC-150 when I first got the plane and worried I'd never have a working AP and I should have just swapped it out even though they were telling me not to. In the end, the repair cost was less than a new AP (~2/3 savings) and it has worked perfectly for 5 years.  However, I have had plenty of problems with the AI which I swapt for the Aspen unit and that isn't so smooth. Quote Link to comment Share on other sites More sharing options...
Jsavage3 Posted August 27, 2013 Report Share Posted August 27, 2013 We have the 30 ALT and it is nice, push the button, hold altitude. Trouble free for, according to the records, 12 years. But it is a lot of money for a button, a box the size of a pack of cigarettes, a pressure transducer, and a servo. Jetdriven, in conjunction with your STEC 30ALT, are you running the KAP 100 AP system?  If so, do you have it coupled to an IFR GPS?  How does it work?  All, does anyone have the KAP 100 and 60PSS system?  Complaints or praise? Quote Link to comment Share on other sites More sharing options...
Earl Posted August 27, 2013 Report Share Posted August 27, 2013 Have had my Mooney for over five years and 500 hours with the 150 and not a single problem. Â Only issue I have is when you are flying a coupled approach you need to hit the APR button before you capture the localizer, otherwise it is hit or miss as to whether it will fly the approach properly. Â Not sure why but it works better when you let it fly into the localizer. Â Would not agree that it is a piece of junk in the least. Â Do wish I had altitude pre-select though. Quote Link to comment Share on other sites More sharing options...
manu damaschin Posted August 29, 2013 Report Share Posted August 29, 2013 I am very happy with my KFC200...simple and reliable, the pnly thing I miss is the VS:) Quote Link to comment Share on other sites More sharing options...
