rockydoc Posted March 6, 2013 Report Posted March 6, 2013 I am buying a 1965 M20C and need a service manual. Does anyone have one in electronic format they would share. Thanks. Quote
carusoam Posted March 6, 2013 Report Posted March 6, 2013 Consider this source. http://www.mooney.com/index.php Best regards, -a- Quote
flight2000 Posted March 6, 2013 Report Posted March 6, 2013 The manuals cross reference for the early years. The ones you'll need are about halfway down the list. Look for the red font... http://www.67m20e.com/m20e_manuals.htm Brian Quote
robert7467 Posted March 6, 2013 Report Posted March 6, 2013 I have one... PM me your email address. I also have the POH in .PDF format as well. Quote
rockydoc Posted March 6, 2013 Author Report Posted March 6, 2013 Thanks for the suggestions guys, but I have looked extensively at www.mooney.com and find no service manuals anywhere. I also checked www.67m20e.com and only found a very abreviated form--definitely NOT a complete service manual. I have found the service manual at several pay sites which i can view, but which will not let me download without giving credit card password, etc. and/or cell phone number, etc. This is not an option for me. Anyone else help? Quote
rockydoc Posted March 6, 2013 Author Report Posted March 6, 2013 Hi Robert 7467. Thanks. How do I PM on this site? Quote
carusoam Posted March 6, 2013 Report Posted March 6, 2013 Use your finger. Tap avatar, tap send message. Type message. Tap send... Best regards, -a- Quote
N601RX Posted March 6, 2013 Report Posted March 6, 2013 Brian's page has the complete manual. Its just below the partial manual. http://www.67m20e.com/Mooney%20M20%20Series%20S-MM%201980.pdf Quote
robert7467 Posted March 6, 2013 Report Posted March 6, 2013 Put your mouse over robert7467 then it will say send msg.... Quote
rockydoc Posted March 7, 2013 Author Report Posted March 7, 2013 Thanks to everone for the help. Its exactly what I needed. Quote
robert7467 Posted March 7, 2013 Report Posted March 7, 2013 No Problem rockydoc1, let me know if you need a copy of the owners manual. Quote
flight2000 Posted March 7, 2013 Report Posted March 7, 2013 Well, I tried: Full Service and Maintenance Manual for M20E*(10MB pdf file) *also for 62-67 M20C, 63-66 M20D, and 67 M20F Brian Quote
David Knies Posted May 2, 2021 Report Posted May 2, 2021 These links are dead. :/ Does anyone still have the file? Quote
Skates97 Posted May 2, 2021 Report Posted May 2, 2021 3 minutes ago, David Knies said: These links are dead. :/ Does anyone still have the file? Check the Downloads section of the site. There are a number of different ones in there. The early ones will apply to a 1965 but I would download the later ones as well. Everything is not exactly the same in the later models but the illustrations are much better and can help. https://mooneyspace.com/files/category/1-engine-reference-manuals/ Quote
David Knies Posted May 2, 2021 Report Posted May 2, 2021 Yeah, the one I found was for 68+ and I wasn't sure about 65 at that point ... Quote
carusoam Posted May 2, 2021 Report Posted May 2, 2021 Welcome aboard David! Any other questions? Best regards, -a- Quote
cliffy Posted May 3, 2021 Report Posted May 3, 2021 The later manuals for the short bodies have much more detail on how things are/were done than the early 64 65 66 manuals. The systems were the same just better detail in the manual Quote
SSimpson77 Posted May 6, 2021 Report Posted May 6, 2021 If downloads doesn’t work I can email them to you but @Skates97has the good link. Like Cliffy said also, the newer IPC and MM are much more in depth and should cover your model. Just read the beginning to make sure your serial number is in it, my 65C was. Quote
Skates97 Posted May 6, 2021 Report Posted May 6, 2021 Just to make it easier, here are some files. Mooney Parts Manual.pdf MAN104-Service and Maintenance.pdf 601145034_MAN106-ServiceandMaintenance.pdf MAN205-Illustrated Parts Catalog.pdf 3 Quote
