12 hours ago, outermarker said:
Has anyonrre made a simple valve compression tool willing to post a drawing with dimensions?  Something like the attached file.
thanks
This is the cool way:
https://valvewizard.com/buynow.html
but I'm sure several have built their own.  Drawings and other design specifications may be more difficult.  As infrequently as you will likely use it, why not borrow?
The valvewizard is not a bad choice for an angle-valve engine.   For parallel valves there are some easier tools, and some DIY methods that also work well.    I have a valvewizard for the angle-valves and one of these for parallel valves:
https://www.aircraftspruce.com/catalog/topages/compressor.php
Edit, there's also this, for Lycoming engines:
https://www.aircraftspruce.com/catalog/topages/compressor2.php
As an FYI: the Valve Wizard lists IO 550 N and G as incompatible with their tool.  I think that covers all generations of the NA big engine long bodies.
https://valvewizard.com/pdf/ExceptionList.pdf
  • Sad 1
Real simple too:
Aluminum angle from home depot -- just measured it so it would fit as needed -- I believe $30 for the aluminum -- very simple...
-Don
6 hours ago, M20F said:
Wait you all don’t just squeeze them with your hands?
A couple of well placed fingers is all that's needed.
22 hours ago, Fly Boomer said:
I may have made a bad assumption (is there any other kind?).  OP profile says M20E.
My point was not a correction on you or meant for the OP, but the general Mooney audience who might be interested in the tool.
