Jpravi8tor Posted April 9 Report Posted April 9 Gentlemen, I have a 75 F s/n 22/1246 and need 2 fuel senders for the rh Wing. The manual states the original sender P/n as inboard 610168-001 and outboard as 610177-001 The part numbers that were installed were Fuel Sender PN#7740-00118/610642-001 Fuel Sender PN# 7740-00117/610243-001 I am working with Air parts of Loch Haven to find some replacements as the original units are BER can anyone verify the part numbers for the rh wing and offer a possible replacement or source? I cant afford CIES at the moment so I must try to find used cores or used working senders. I am going to start the process and any info would be appreciated. Thanks in advance
DCarlton Posted April 9 Report Posted April 9 9 minutes ago, Jpravi8tor said: Gentlemen, I have a 75 F s/n 22/1246 and need 2 fuel senders for the rh Wing. The manual states the original sender P/n as inboard 610168-001 and outboard as 610177-001 The part numbers that were installed were Fuel Sender PN#7740-00118/610642-001 Fuel Sender PN# 7740-00117/610243-001 I am working with Air parts of Loch Haven to find some replacements as the original units are BER can anyone verify the part numbers for the rh wing and offer a possible replacement or source? I cant afford CIES at the moment so I must try to find used cores or used working senders. I am going to start the process and any info would be appreciated. Thanks in advance Mooney allows upgrade from the F senders to the J model senders. I'll find the info and post. I also have four senders I just removed from my airplane (3 original F model and 1 J model). The J model sender appears to be working fine (610243-1). It could be overhauled by Air Parts. John Breda (here on MS) used to have a few more J model units available. 1
KSMooniac Posted April 9 Report Posted April 9 I've got some J senders as well from my upgrade. Sent from my motorola edge plus 2023 using Tapatalk
Jpravi8tor Posted April 9 Author Report Posted April 9 can you seend me the part numbers? how much would you need for them?
DCarlton Posted April 9 Report Posted April 9 This is what Mooney told me for my '67F: 1. Original 610161 LH Outboard is now 610243-003 (same as the M20J) 2. Original 610160 RH Outboard is now 610243-001 (same as the M20J) 3. Original 610168-001 both inboard is now 610242-001 (same as the M20J) 1 1
DCarlton Posted April 9 Report Posted April 9 39 minutes ago, Jpravi8tor said: can you seend me the part numbers? how much would you need for them? Searching through my emails, it looks like Air Parts wanted $383 each overhauled in 2024 with a $200 core charge. I think new they were twice that. I paid $300 each for three overhauled gages from someone on MS. I was going to keep it as a spare but if you need it, I'll send you 610243-1 for $150. I bench checked it and it works but I'd have it overhauled to be certain.
M20F-1968 Posted April 28 Report Posted April 28 On 4/9/2025 at 11:57 AM, Jpravi8tor said: Gentlemen, I have a 75 F s/n 22/1246 and need 2 fuel senders for the rh Wing. The manual states the original sender P/n as inboard 610168-001 and outboard as 610177-001 The part numbers that were installed were Fuel Sender PN#7740-00118/610642-001 Fuel Sender PN# 7740-00117/610243-001 I am working with Air parts of Loch Haven to find some replacements as the original units are BER can anyone verify the part numbers for the rh wing and offer a possible replacement or source? I cant afford CIES at the moment so I must try to find used cores or used working senders. I am going to start the process and any info would be appreciated. Thanks in advance I have 2 senders, Part No. 610242-1. Both have been rebuilt by Airparts of Lockhaven with paperwork for return to service. I also have one as removed. $250 each for the rebuilt on. $100 for the as removed of B/O fir that one. These are the last of the senders I have. They are legal to put in an F. The only other senders I would use are the CIES senders (which I now have) but you also need a digital system which you likely do not have. I would just take all 3, The prices have gone crazy. You will then have an extra to readily install and an extra to rebuild. John Breda cell: (617) 877-0025 email: john.breda@gmail.com
