The pilot yoke button switch that clears the Stormscope display on the 530 broke off.  The part number was not supplied by BF Goodrich, but was installed at Kerrville.
Would appreciate any leads to determine the part number for replacement.
Spruce sells lots of buttons more than likely you will want a single pole momentary.   Digikey has every button switch you could imagine.    More than likely you can find a part number or something on the switch to look up.    Your soldering skills will be put to the test to R&R.   I would greatly suggest a Weller Soldering Station.
