I just purchased a 1996 J.   During transition training when we ran the King A/P preflight check the lights blinked as planned.  My instructor thought there was also supposed to be audible beeps to confirm a successful test although I couldn’t find this in the POH A/P preflight instructions.   Any other J owners out there with KAP-150 can confirm if your autopilot ‘beeps’ at preflight.   Thanks.
It's not in the POH, it's in the King KFC 150 manual.  I have a KFC 200 and it's basically the same.
Here's a link to download the manual: https://www.bendixking.com/content/dam/bendixking/en/documents/downloads/006-08377-0001_1-kap-150-ki-525a-pilot-s-guide.pdf
Here's the key section: To perform a test - momentarily push the test button: 1. All annunciator lights, the trim light and autopilot light will illuminate. 2. The trim light will flash 4 times. 3. The annunciator legends will be blank, an aural tone will beep (approx. 6 times) and the "AP light will flash (approx. 12-13 times) and go off. (If the AP light fails to flash you will be unable to engage the autopilot.) 4. The KC 191 display will go blank.
The KFC-150 in my J beeps five times if all's well -or- forever (or until I pull the CB) if something causes it to not pass its self test.  This happens for instance if somehow the Elec. Trim power switch is inadvertently switched off.  That's actually a good way to test your sonalert.
