Does anyone know where to purchase a "rebuild/overhaul kit" for a Dukes Fuel Boost Pump #4140-00-19A?  If it is not rebuildable, then does anyone on the list have a used Dukes pump for sale or a Weldon 10054A?  I understand the Weldon is a direct replacement for the Dukes.  Are there any other pumps that can be an option?  Thanks.      Mike
By the way, the Weldon is not a direct replacement.  Drawings for the replacement are available and it is not very complicated.  But it is not just a matter of bolting it in.  I looked at it and decided to stay with Dukes.
Thanks for all your replies.
The Ebay pump will not work.  My M20G uses a low pressure pump-----6 psi max.
I'll be calling Russ to see what he can do, as far as repairing my old one.
To the gentleman with the Weldon, could you send some pictures to rmclemns@yahoo.com    I'll also need a closeup of the data plate so I can assure myself that it will fit and work in my M20G.
