Hradec Posted December 10, 2023 Report Posted December 10, 2023 Going through all the pushpull tubes and rod ends on my aircraft renovation project. The parts manual diagram is very poor for the nose gear door rod end. later models Parts catalog looks different. Is my part correct or is it completely wrong and as my friend said, a riding lawn mower rod end? Please share a pic of your rod end from same vintage mooney. Thanks Glenn 1964 m20e sn #311
Dialed In Posted December 11, 2023 Report Posted December 11, 2023 These are what mine looked like before I replaced them, 1965 e.
takair Posted December 11, 2023 Report Posted December 11, 2023 2 hours ago, Hradec said: Going through all the pushpull tubes and rod ends on my aircraft renovation project. The parts manual diagram is very poor for the nose gear door rod end. later models Parts catalog looks different. Is my part correct or is it completely wrong and as my friend said, a riding lawn mower rod end? Please share a pic of your rod end from same vintage mooney. Thanks Glenn 1964 m20e sn #311 That’s what my 1964 has. Not aware of a mower that uses that version. The end is adjustable but after 59 years they can be quite worn…. They also appeared on throttle and mixture linkages, those are typically long replaced due to wear and tear.
47U Posted December 11, 2023 Report Posted December 11, 2023 2 hours ago, Hradec said: Please share a pic of your rod end from same vintage mooney. 4 minutes ago, takair said: They also appeared on throttle and mixture linkages, those are typically long replaced due to wear and tear. Here’s a pic of m7 ‘63C… like takair says, the engine connections (throttle/prop?) are subject to so much vibration, they should be swapped out for Heim bearings. I think Mooney did a service bulletin to do that.
Hradec Posted December 11, 2023 Author Report Posted December 11, 2023 24 minutes ago, 47U said: Here’s a pic of m7 ‘63C… like takair says, the engine connections (throttle/prop?) are subject to so much vibration, they should be swapped out for Heim bearings. I think Mooney did a service bulletin to do that. Bingo! Thanks, for the picture and confirmation it is correct. Part number anyone? The parts catalog for my year is really poor. Possible service bulletin for update? Thanks Glenn
47U Posted December 11, 2023 Report Posted December 11, 2023 5 hours ago, Hradec said: Possible service bulletin for update? There wasn’t a SB to replace the ball/swivel rod ends on the nose gear doors. I’m not sure if a Heim bearing gives enough rotational clearance… perhaps with a short spacer? As far as part numbers… my IPB lists a ‘link, retraction’ as pn 8129, superseded by pn 550021. Mooney part numbers really don’t cross reference to mil spec or AN / MS standard part numbers. Aircraft Spruce carries some ball joints, as I’m sure do others… I’m sure there’s a replacement available either new or from a salvage outfit. 1
