jamesm Posted August 23, 2023 Report Posted August 23, 2023 I have been admiring the rounded cabin window corner look on early model Mooney's. I believe 64 or 65 and later is when Mooney came out with the square corner look for the rear cabin windows. I am curious to know the secret in the labor and technique in making that look. Thanks in advance, James '67C
ArtVandelay Posted August 23, 2023 Report Posted August 23, 2023 You can just paint the rounded corners. 1
jamesm Posted August 23, 2023 Author Report Posted August 23, 2023 18 minutes ago, ArtVandelay said: You can just paint the rounded corners. I guess I had never thought of that I had only seen early model Mooney's with that look from pictures from a far.
Kelpro999 Posted August 24, 2023 Report Posted August 24, 2023 You can template a rounded window, vinyl wrap your windows, cut around the template and pull out the center. Vinyl comes in many colors 1
jamesm Posted August 24, 2023 Author Report Posted August 24, 2023 3 hours ago, Kelpro999 said: You can template a rounded window, vinyl wrap your windows, cut around the template and pull out the center. Vinyl comes in many colors is there such thing as color matching in vinyl wraps?
Kelpro999 Posted August 24, 2023 Report Posted August 24, 2023 11 hours ago, jamesm said: is there such thing as color matching in vinyl wraps? Vinyl comes in all colors, depending on type. Contact a wrap company and you may get some remnants for nothing
M20F-1968 Posted August 24, 2023 Report Posted August 24, 2023 Or you can reskin the airplane from the baggage compartment forward as I did. John Breda 2
