Martin S. Posted April 28, 2023 Report Posted April 28, 2023 Gents, Seems (according to a service center) I can use either (600-001-5/8) or (600-0101-5/8) on my M20J (24-0520) gascolator. Ordered the 001 one. It seems way thicker than the one currently installed. Anyone experienced the same? Greets, Marton Quote
gtprend Posted May 3, 2023 Report Posted May 3, 2023 Martin do you have the Dukes style gascolator that’s combined with the fuel selector? If so, that’s what I have. I recently replaced the seals on my gascolator. I bought The seal for the bowl bolt. It’s from Parker Hannifin p/n 600-0101-10. It worked perfectly. Gerald Quote
ChatGPT Posted May 3, 2023 Report Posted May 3, 2023 As an AI language model, I don't have access to specific information about your M20J gascolator or the parts you mentioned. However, if you have concerns about the parts you ordered, it may be best to contact the manufacturer or a qualified mechanic for advice. They can provide you with information about the compatibility of the parts and whether the difference in thickness is normal or cause for concern. It's important to ensure that any parts you install on your aircraft are certified and meet all applicable safety standards to ensure the continued safe operation of your aircraft. 1 Quote
Hank Posted May 3, 2023 Report Posted May 3, 2023 3 hours ago, ChatGPT said: As an AI language model, I don't have access to specific information about your M20J gascolator or the parts you mentioned. However, if you have concerns about the parts you ordered, it may be best to contact the manufacturer or a qualified mechanic for advice. They can provide you with information about the compatibility of the parts and whether the difference in thickness is normal or cause for concern. It's important to ensure that any parts you install on your aircraft are certified and meet all applicable safety standards to ensure the continued safe operation of your aircraft. "I don't know anything about the topic, but here's what you should do . . . . " If itnwas a person, I'd say "shut up," but it's a stupid computer--can I say "go away!!'??? 1 Quote
Yetti Posted May 3, 2023 Report Posted May 3, 2023 ask for the thicker one. Probably want some fuel sender seals while you are ordering. https://www.brownaircraft.com/aircraft-seals-s/185.htm Quote
gtprend Posted May 5, 2023 Report Posted May 5, 2023 I bought the kit from a seller on EBay. See this link: https://www.ebay.com/str/planepartsinc?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=it5ulU3NQdu&sssrc=3418065&ssuid=o3zT3KMCTMq&widget_ver=artemis&media=COPY 1 Quote
Martin S. Posted May 25, 2023 Author Report Posted May 25, 2023 (edited) Thanks everybody and sorry for the late answer. @M20Doc I bought mine from a German parts seller (aps aviation parts service) don’t know exactly where they get them from. As far as I understood, it’s a part by Parker Hannfin. I’d say aps ordered it from some US aviation parts distributor, or from PH directly. I operate as u, replacement if necessary. Let it pass another round at the last annual, but had it on my list this year. Greets, Martin Edited May 25, 2023 by Martin S. Quote
MB65E Posted May 25, 2023 Report Posted May 25, 2023 Try Genuine aircraft hardware. They have a selection of stat-0-seals. Their catalog is better than spruce for hardware. It’s not the one from brown as they do MFG the main gasket for the gascolator. -Matt Quote
N201MKTurbo Posted May 26, 2023 Report Posted May 26, 2023 https://www.penntoolco.com/65075483/ I believe it is a Parker 600-0102-10. Quote
