Chris newton Posted April 8, 2022 Report Posted April 8, 2022 I need to replace the cowl flap indicator cable on a 1989 M20J . Where might I find one ? Quote
KSMooniac Posted April 8, 2022 Report Posted April 8, 2022 The cable is just a steel wire inside the sheath, but the indicator end is likely a clear plastic piece with a black end, if it is like the earlier ones I'm familiar with. Does that sound right?If the plastic piece is indeed broken, you might have to glue it back together or fabricate a replacement. It is very delicate! If the steel wire broke, you can source that from just about anywhere and just feed it through the sheath from the flap actuator end. You can rig it in the flaps-up position, and check it through the full travel. Sent from my LM-V405 using Tapatalk Quote
amillet Posted April 8, 2022 Report Posted April 8, 2022 My indicator (plastic piece) fell off the cable. Greg at Advanced (MSC at KTTD) was able to glue it back on. Requires removing the plastic housing Quote
Chris newton Posted April 8, 2022 Author Report Posted April 8, 2022 The plastic indicator piece is in good shape .so I just need the cable. Thanks for the replies Quote
PT20J Posted April 8, 2022 Report Posted April 8, 2022 The generic name for that type of cable is Bowden cable. Search for that and you should find lots of sources. 1 Quote
kortopates Posted April 8, 2022 Report Posted April 8, 2022 The generic name for that type of cable is Bowden cable. Search for that and you should find lots of sources. Exactly, just replace with the same diameter.Sent from my iPhone using Tapatalk Quote
