Piloto Posted January 12, 2012 Report Posted January 12, 2012 After 900 hours my Rapco pump failed. Actually was not the pump but the rubber shaft coupler. The pump was still operable. You could make the pump turn by itself by sucking into the inlet port. Luckyli my trusty $7 venturi back up took care of the failure and I was able to continue my trip for the next 8 hours. I switched to venturi to avoid the need to reduce power when using the engine intake vacuum scheme. Which is worthless at altitude when you have full throttle. The venturi works pretty well except on the ground since you need airspeed to work. José Quote
sreid Posted January 12, 2012 Report Posted January 12, 2012 That looks like the exit port of a pee tube. Quote
Piloto Posted January 12, 2012 Author Report Posted January 12, 2012 Quote: sreid That looks like the exit port of a pee tube. Quote
Ned Gravel Posted January 12, 2012 Report Posted January 12, 2012 José: Where is the front end of the venturi located in your setup here? Quote
Piloto Posted January 12, 2012 Author Report Posted January 12, 2012 Quote: edgargravel José: Where is the front end of the venturi located in your setup here? Quote
garytex Posted January 12, 2012 Report Posted January 12, 2012 Quote: Piloto Well, a second application for it for the same price. No need to worry anymore about bottles. Thanks for the tip. José Quote
sreid Posted January 12, 2012 Report Posted January 12, 2012 So does that seriously generate enough vacuum to power your gyros? What vacuum pressure does it generate at various airspeeds? Do you have a picture of the other end at the pump? Cool! Quote
Piloto Posted January 13, 2012 Author Report Posted January 13, 2012 Quote: sreid So does that seriously generate enough vacuum to power your gyros? What vacuum pressure does it generate at various airspeeds? Do you have a picture of the other end at the pump? Cool! Quote
1964-M20E Posted January 13, 2012 Report Posted January 13, 2012 That is neat. I wonder since this is reducing the back pressure on the vacuum pump will the pump last longer since it is not working as hard. Quote
Piloto Posted January 13, 2012 Author Report Posted January 13, 2012 Quote: 1964-M20E That is neat. I wonder since this is reducing the back pressure on the vacuum pump will the pump last longer since it is not working as hard. Quote
