So a coat of matte clear paint with UV protection and a fresh set of screws.  Instead of the painted steel screws I used black brass (MS35214-12).  Even though the IPC showed two different screws, all 22 screws were the same (4-40 x 1/4").
  • 1 year later...
1 hour ago, hazek said:
How does one fix this on a Bravo? Has anyone repaired their's before?
There are couple threads in here. General idea is to remove the top layer (a solvent works), clean, and apply a coating (spraying works). You get a result like this.PXL_20230508_0052513352.jpg.33f6e771173c1081c8d3ef9111d25bcf.jpg
