Problems with MIC-Socket on RH side - different from LH side ?
I spent the whole weekend trying to wire a LEMO-Socket on the RH side in aprallel to the exsiting PJ-sockets-I thin, this is the normal procedure
I did this already on the LH side and it was easy. So should be on the RH side.
The Headphone socket was easy - the headset gets power from the Lemo-Socket (coming from Radio-Master) and the headphones work - fine.
But not for the MIC-part. This doesn't work.
I have a white wire with MOoney-labeling on the ring-contact and an orange-white wire on the tip-contact. The white wire disappears to the center console, while the orange-white wire goes up on the right side. Maybe this goes to our intercom? No wire on the barrel (the housing of the PJ-socket)
According to the manual for the Bose-socket, I wired the white wire (comiung from the Lemo-socket) together to the ring. The left side looks the same.
The light-blue-white wire goes to the barrel.
But then it runed out, that COM1 is transmitting permanently (it is a GNS430W), while COM2 starts transmittting only with pressing the MIC-button.
Any ideas? Maybe my brain is frozen.
