Gear warning Light problem
I have a 1975 M-20F and have light problems.  The warning light stays on except when gear is up.  Actually the gear warning and gear down lights work at the same time.  Both go on and off at the same time Anyone have an Idea.  I cant find a wiring diagram for my Aircraft.  The one I have is for a 1974.  John
Edited by John Fletcher
Link to comment
Share on other sites
The problem probably lies in your up limit switch. Each switch is a double pole, normally open and normally closed. It sounds like the normally open position is failed as that's the one that drives the light. IIRC
Sent from my Pixel 2 XL using Tapatalk
Link to comment
2 hours ago, PilotCoyote said:
I wish mine did that- it’s annoying to fly around with a red light on the panel! I have wondered whether Mooney changed this feature in the later year models...
Good news... they changed it before your plane was built...
Find the light... twist the lens clockwise...
The big ugly light is big and ugly for a reason...
It is hiding a mechanical iris in there...
Twisting it opens and closes the iris...
Give it a try...
Just make sure you don’t close the green one completely... :)
If airplane manufacturers wrote POHs back in the day... they would have covered how all the controls work...
PP thoughts as usual...
Link to comment
Give it a try...
Yes, I know about the iris:)....but I am always hesitant to close it for fear of forgetting to open it back up!
Link to comment
