ELT Posted November 18, 2019 Report Posted November 18, 2019 Hi My inspector requested me to find him a contact for information on doing an access panel to install the sb20-217 kit. I see that Dave has done this. How can I contact Dave by phone or email? I can be contacted by 919.819.3451 or edwin.l.todd@gmail.com. Don Maxwell suggested taking rivets out off a belly panel to access. Has anyone done this? thanks for any help Eddie Quote
RLCarter Posted November 18, 2019 Report Posted November 18, 2019 @Sabremech someone is looking for you 1 Quote
Guest Posted November 18, 2019 Report Posted November 18, 2019 3 hours ago, ELT said: Hi My inspector requested me to find him a contact for information on doing an access panel to install the sb20-217 kit. I see that Dave has done this. How can I contact Dave by phone or email? I can be contacted by 919.819.3451 or edwin.l.todd@gmail.com. Don Maxwell suggested taking rivets out off a belly panel to access. Has anyone done this? thanks for any help Eddie With the flap area cover removed you can access most of the rear spar. Start at the back of the baggage compartment floor and drill out enough rivets to gently lift/ roll the floor forward to allow fitting and riveting of the reinforcement doublers. Clarence Quote
MB65E Posted November 18, 2019 Report Posted November 18, 2019 Some have made a patch in the floor for access. Pulling up the floor And gaining access I think is the hardest part. edit: getting a new SB kit may be the hardest part now. -Matt Quote
Andy95W Posted November 18, 2019 Report Posted November 18, 2019 I did this SB a few years ago. The instructions for compliance are very well written and very clear. I can't speak for Don Maxwell or his folks, but I am very sure he was not implying removing any external belly skins. I bought my SB parts from LASAR. They said that they had some experience with cutting access holes in the baggage compartment floor (since it's non structural) and simply patching the holes when finished. That's what I did. It might've saved me 2 hours' time, total. In hindsight, I would do the job exactly per the SB by drilling the rivets from the baggage floor. Clarence describes this above. Just like he said, start at the back and work forward until you can peel up enough of the floor to accomplish the SB. It sounds like your mechanic is looking for a shortcut, if one is available. There really isn't one. It sounds like you're on good terms with him- I'd suggest doing everything you can to remove your baggage compartment interior and your rear seat to make things smoother for him. Good luck, it's kind of a pain but not really that difficult. Quote
Sabremech Posted November 18, 2019 Report Posted November 18, 2019 Hi Eddie, Yep, I did mine with making a simple access panel in the floor of my baggage compartment. I had spoken with someone, think it was Paul Loewen about it and found that I'd much rather make a simple access panel versus drilling out the baggage floor just to buck a couple of rivets in the bracket. I can give you a call and then we can go over it. My e-mail is sabremech at gmail.com Thanks, David Quote
