PT20J Posted October 29, 2019 Report Posted October 29, 2019 The Precise Flight ICA calls for lubricating the gears annually. I couldn't find any indication that mine had been lubed since they were sent to the factory for overhaul by the previous owner seven years ago. The ICA calls for removal to lube, but that's not really necessary. I found that by removing the bottom plate I could inspect the worm and worm gear. They were dry. I was able to access the sector of the gear that needed lube by raising the speed brakes and applying Aeroshell 22 to the gears with a long Q-tip. The design is such that the gears are exposed to water coming in from the top of the wing which can wash out the grease. If the airplane is left outside in the rain at all, an annual lube is a good idea. Skip 541SMAN0001D.pdf 4 Quote
MikeOH Posted October 29, 2019 Report Posted October 29, 2019 Good to know! I suspect mine have been neglected...annual coming in December. Quote
RLCarter Posted October 29, 2019 Report Posted October 29, 2019 1 hour ago, PT20J said: The Precise Flight ICA calls for lubricating the gears annually."...............If the airplane is left outside in the rain at all, an annual lube is a good idea Isn't it required to lube them annually? Quote
PT20J Posted October 29, 2019 Author Report Posted October 29, 2019 1 hour ago, RLCarter said: Isn't it required to lube them annually? It's in the instructions for continued airworthiness to be done annually, but this isn't mandatory for part 91. Quote
RLCarter Posted October 29, 2019 Report Posted October 29, 2019 1 hour ago, PT20J said: It's in the instructions for continued airworthiness to be done annually, but this isn't mandatory for part 91. Thanks, sometimes it easier to ask than dig through the Regs Quote
buddy Posted October 29, 2019 Report Posted October 29, 2019 I just lubricated mine about a month ago, pulled the unit out from the top and lubricated the worm gear through the inspection hole. Easy job and I’m going to make sure I do it annually. Quote
