Oldguy Posted December 5, 2018 Report Posted December 5, 2018 14 hours ago, Cruiser said: All true except for the airplanes that are not seen by the ATC radar. IF ATC cannot see them then you will not see them either. This is most likely to occur around remote airports that are not in range of radar coverage at the pattern altitude. In this case there can be a bunch of airplanes buzzing around that will not be seen other than visually. Better wording for what I was trying to get across. Thanks.
Browncbr1 Posted December 6, 2018 Report Posted December 6, 2018 Since you’re timing this right and you might want to Stand by for the Dynon skyview suite STC. From what you described, it sounds like a either a gtn 650 or a slide in replacement IFD and a skyview may solve all your needs. 1
