8 minutes ago, Oscar Avalle said:
No, you can not adjust fuel flow legally on our carb...
But there are different versions that can be installed.
Yes you are right, just make sure that you have the Mooney one and rich version. Another aspecto to consider is that all the hoses are of the right diameter. Last but not least the fuel pump. I worked on all that and was able to get an increase in my fuel flow and a better cooling
2 hours ago, Hank said:
Aren't there several different dash numbers for the carb jets that can be swapped out to change fuel flow in our O-360s?
From the MSA Carbs website.
