Wildenschild Posted May 25, 2018 Report Posted May 25, 2018 (edited) We have an issue with our Mooney Ovation 2 year 2005 with Garmin 1000 avionics. It started when the throttle was reduced, the engine instrument fuse (MFD fuse) poped out. Now it pops out all the time. Has anybody experienced that problem on your speed machines? Edited May 25, 2018 by Wildenschild Pic attached Quote
kortopates Posted May 28, 2018 Report Posted May 28, 2018 You likely have a chaffed wire behind the panel that is shorting out somewhere. Maybe where the engine control cables go through if popping was reproducible moving mixture but could be anywhere. Look for signs of burning and arcing till you find it.Sent from my iPhone using Tapatalk Quote
Wildenschild Posted May 28, 2018 Author Report Posted May 28, 2018 Thanks for all your input. The plane is in the workshop now, I will let you know how they fix the problem. Br Lars 1 Quote
carusoam Posted May 28, 2018 Report Posted May 28, 2018 Lars, See if you can get a picture of the cause? That is a pretty spooky failure. Best regards, -a- Quote
Wildenschild Posted May 29, 2018 Author Report Posted May 29, 2018 It was the tag sensor (RPM pick-up)on the LH mag. Do you Guys know the part number? Quote
carusoam Posted May 30, 2018 Report Posted May 30, 2018 @M20Doc might be familiar...? Best regards, -a- Quote
Wildenschild Posted May 30, 2018 Author Report Posted May 30, 2018 This bandit caused the issue. 2 Quote
