Rookie Posted July 22, 2017 Report Posted July 22, 2017 Does anyone know where the annunciator reads the voltage from? Mine keeps blinking but I know I have 13.6 while flying. Sent from my iPhone using Tapatalk
DVA Posted July 22, 2017 Report Posted July 22, 2017 Hi Rookie, assuming for a moment that your alternator and the regulator is operating correctly and that you do not indeed have a low voltage condition, it's not uncommon to see the lamps illuminate errantly due to one of two leaky diodes on the circuit board in the annunciation panel. I have a schematic somewhere, and it's not a difficult field repair. There are a few places that will work in those only oem boxes, maybe someone else can chime in. 1
carusoam Posted July 22, 2017 Report Posted July 22, 2017 Somebody has posted the wiring diagrams for the anunciator panel before... Not sure which years are covered. The drawing combined with DVA's advice is a pretty strong way to have an instrument tech test for things that aren't wotking properly... Isn't there and adjustment for that? anything over 13v is a sign that the alternator is working...(?) A fully charged battery doesn't usually show 13+v while not being charged...(?) the details of the anunciator panel are kept in the MM. PP thoughts only... Best regards, -a- 1
kortopates Posted July 22, 2017 Report Posted July 22, 2017 Does anyone know where the annunciator reads the voltage from?Mine keeps blinking but I know I have 13.6 while flying. Sent from my iPhone using Tapatalk 13.6 v is a bit low, your battery wants 14.0v for maximum longevity. Sent from my iPhone using Tapatalk 1
Rookie Posted July 23, 2017 Author Report Posted July 23, 2017 I need to look in POH but the light should not come on over 12 volts. I though I read that.
kortopates Posted July 23, 2017 Report Posted July 23, 2017 I need to look in POH but the light should not come on over 12 volts. I though I read that. I'd have to look it up too, but you're off by at least a volt - I would expect lower 13v range. You're no longer charging when it drops to 13v.Sent from my iPhone using Tapatalk
ArtVandelay Posted July 23, 2017 Report Posted July 23, 2017 Schematic is in the service manual. Lee Only for serial 3154 and later, earlier Js you have to refer to a drawing which I don't have in the electronic copy of the service manual. Nice troubleshooting section, anyone actually have the drawings? The supplement schematics are only the plane's wiring. 1
Rookie Posted July 25, 2017 Author Report Posted July 25, 2017 I flew it again Monday and the light did not come on.
Guest Mike261 Posted July 25, 2017 Report Posted July 25, 2017 I see the light at idle only, taxiing and such. I find the hotter the ambient is the higher the RPM has to be to extinguish the light. on the hottest days 1180 will extinguish the light. I can go from september to june and never see it lit once, but i see it during the dog days of summer. (98 J) Mike
EricJ Posted July 25, 2017 Report Posted July 25, 2017 A real easy way to monitor the system voltage is with one of these things plugged into the cigar lighter: https://www.amazon.com/Car-Charger-Smartphone-Temperature-Fahrenheit/dp/B00SWGWILI/ref=sr_1_1?ie=UTF8&qid=1501025200&sr=8-1&keywords=usb+charger+voltage+meter The display cycles between input voltage, output current (the current at 5V to whatever USB devices are plugged into it), and the ambient temperature. I've been flying with one of these powering all the USB doo-dads for a while and it's really handy to peek at the display and see what the system voltage is up to. 1
Rookie Posted July 26, 2017 Author Report Posted July 26, 2017 17 hours ago, EricJ said: A real easy way to monitor the system voltage is with one of these things plugged into the cigar lighter: https://www.amazon.com/Car-Charger-Smartphone-Temperature-Fahrenheit/dp/B00SWGWILI/ref=sr_1_1?ie=UTF8&qid=1501025200&sr=8-1&keywords=usb+charger+voltage+meter The display cycles between input voltage, output current (the current at 5V to whatever USB devices are plugged into it), and the ambient temperature. I've been flying with one of these powering all the USB doo-dads for a while and it's really handy to peek at the display and see what the system voltage is up to. I actually have one just like that. That's how I knew my alt. was charging and the battery voltage was ok. 1
trevttu76 Posted February 13, 2023 Report Posted February 13, 2023 I know this is an old thread, but got me thinking I see similar issues. Where is the voltage regulator box in a J model? I have a 1978 to be exact. I can't recall seeing it under the panel...
N201MKTurbo Posted February 13, 2023 Report Posted February 13, 2023 4 minutes ago, trevttu76 said: I know this is an old thread, but got me thinking I see similar issues. Where is the voltage regulator box in a J model? I have a 1978 to be exact. I can't recall seeing it under the panel... it is bolted to the firewall on the copilots side about 6 inches down from the glare shield. 1
ArtVandelay Posted February 13, 2023 Report Posted February 13, 2023 it is bolted to the firewall on the copilots side about 6 inches down from the glare shield. Mine (78) is more on the side by the vent on copilot’s side. FWIW 1
PT20J Posted February 13, 2023 Report Posted February 13, 2023 My 78 had a rather large OECO regulator mounted on the firewall up high under the glare shield. My 94 has a Mooney regulator which is much smaller and located at the base of the copilot's panel just to the right of the center console on top of a small tray.
kortopates Posted February 14, 2023 Report Posted February 14, 2023 My 78 had a rather large OECO regulator mounted on the firewall up high under the glare shield. My 94 has a Mooney regulator which is much smaller and located at the base of the copilot's panel just to the right of the center console on top of a small tray.And that is the difference between the 14v and subsequent 28v installations. Sent from my iPhone using Tapatalk 1
trevttu76 Posted February 15, 2023 Report Posted February 15, 2023 On 2/13/2023 at 3:13 PM, N201MKTurbo said: it is bolted to the firewall on the copilots side about 6 inches down from the glare shield. Is this the VR? This is mounted along a plate perpendicular to the firewall close to the glare shield (co-pilot side). If so, does anyone recognize the model and know if there is an adjustment to raise the voltage a bit.?? My voltage is consistent, but mid 13's, would like to get it closer to 14V for my Concord RG.
OR75 Posted March 31, 2023 Report Posted March 31, 2023 this looks like a Lamar Electrodelta VR415 regulator
