peevee Posted March 4, 2017 Report Posted March 4, 2017 Seems like we constantly have trouble with the cable on/off system. If I could find a solenoid valve of the appropriate fitting size it doesn't seem like it would be a difficult fix to put that in between the factory regulator and the tank and run it to a switch and just leave the original valve open. Downside being I guess you'd have to open it to fill the tank. Something like:http://www.stcvalve.com/solenoid_valve_specifications_and_dimenisons_2SO_2WO.htm but in a normally closed config. I think mountain high uses something similar on their built in kits too.
carusoam Posted March 4, 2017 Report Posted March 4, 2017 Sounds like an intelligent way to go. - more reliable than the old cable method. - minimal maintenance to swap out worn parts. - minimal weight compared to the old cable. - add a fancy switch to match an empty spot in the instrument panel. - Have STC written by one of our STC writers. - a switch with a status light would be nice. - normally closed to preserve O2 in the tank while not in use, no electrical use while not flying. Nice outside the box thinking, PV. Best regards, -a-
peevee Posted March 4, 2017 Author Report Posted March 4, 2017 I think commercial solutions exist also, mountain high for example has this: http://www.mhoxygen.com/index.php/closeout-refurbished scroll down to the ARCVR-0100-11 Problem on the mooney would be the necessity to integrate with the factory ports and lines, so you would either need something with similar output and config, or as I said put something inline.
carusoam Posted March 4, 2017 Report Posted March 4, 2017 You can power up a refurbed O2D2 at the same time... If it doesn't need to run on batteries? Best regards, -a-
peevee Posted March 4, 2017 Author Report Posted March 4, 2017 1 minute ago, carusoam said: You can power up a refurbed O2D2 at the same time... If it doesn't need to run on batteries? Best regards, -a- You could but I think it runs on 3AA batteries so it probably isn't worth the headache to work out the voltage to ships power. 1
Guest Posted March 4, 2017 Report Posted March 4, 2017 5 hours ago, peevee said: Seems like we constantly have trouble with the cable on/off system. If I could find a solenoid valve of the appropriate fitting size it doesn't seem like it would be a difficult fix to put that in between the factory regulator and the tank and run it to a switch and just leave the original valve open. Downside being I guess you'd have to open it to fill the tank. Something like:http://www.stcvalve.com/solenoid_valve_specifications_and_dimenisons_2SO_2WO.htm but in a normally closed config. I think mountain high uses something similar on their built in kits too. Standard equipment on most Cirrus models. Clarence
