tls pilot Posted May 22, 2016 Report Posted May 22, 2016 Any source for the split switches in late models M 20. The split switch for Left landing light broke in half Please let me know a good source and how to replace etc thx Quote
carusoam Posted May 23, 2016 Report Posted May 23, 2016 It helps if you have the model number and the manufacturer of the switch. Aircraft Spruce has been able to get some from the switch OEMs. The switch OEMs have their own outlets for selling switches singly... expect that they are in the $200 bracket. The specialized double switches will be dissapointingly more... I have not found a way to just replace the plastic switch covers... Does any of this sound familiar? Hope that helps, -a- Quote
DVA Posted May 23, 2016 Report Posted May 23, 2016 Superglue for the plastic portion works. I’ve had a few “new” superglue switches installed over the years. After that they seem to last forever and they are cheap! Quote
LANCECASPER Posted May 23, 2016 Report Posted May 23, 2016 JB Weld from the Aviation aisle at Home Depot works well too Quote
StevenL757 Posted May 26, 2016 Report Posted May 26, 2016 TLS - just sent you a PM. Regards, Steve Quote
Bravoman Posted May 26, 2016 Report Posted May 26, 2016 On May 23, 2016 at 7:15 PM, LANCECASPER said: JB Weld from the Aviation aisle at Home Depot works well too Is there really an aviation aisle at Home Depot? Quote
LANCECASPER Posted May 26, 2016 Report Posted May 26, 2016 2 hours ago, Bravoman said: Is there really an aviation aisle at Home Depot? There is an aviation aisle at Home Depot, Lowes, True Value, etc . . . Just kidding, the hangar elves many times do their shopping in these aisles. Quote
kortopates Posted May 27, 2016 Report Posted May 27, 2016 2 hours ago, Bravoman said: Is there really an aviation aisle at Home Depot? There is an aviation aisle at Home Depot, Lowes, True Value, etc . . . Just kidding, the hangar elves many times do their shopping in these aisles. No way - my Home Depot has an aviation aisle - in fact it's stocked by Santa himself every Christmas! Sent from my iPhone using Tapatalk Quote
Fishnpilot Posted December 29, 2016 Report Posted December 29, 2016 On May 23, 2016 at 4:15 PM, LANCECASPER said: JB Weld from the Aviation aisle at Home Depot works well too did you ever find a switch to replace the split rocker landing/taxi I have same problem but it's beyond glue needs replaced any info would be greatly appreciated been searching for a while Quote
carusoam Posted December 30, 2016 Report Posted December 30, 2016 Welcome on your first visible post Fishn! Stand by for an answer. It is a bit late on the east coast. Best regards, -a- Quote
Rick Junkin Posted January 12, 2017 Report Posted January 12, 2017 I had great luck with LASAR today with getting replacements for my avionics master switch and my BAT 1/BAT 2 switch. If you have the part numbers they can look them up for you. For aircraft serial numbers 27-0001 through 27-0257: 880052-521 switch, landing light 880052-523 switch, taxi light Quote
Rick Junkin Posted January 12, 2017 Report Posted January 12, 2017 Sorry, contact information for LASAR is www.lasar.com, parts ordering phone (707) 263-0581. Cheers, Rick Quote
