MHemperly Posted October 6, 2015 Report Posted October 6, 2015 (edited) does anyone know if this clock can still be purchased from davtron? Or does anyone know of one for sale or where I can even find a used one? ive looked on davtron's site and can't find it. This is not my panel btw. I have the old anolog clock with sweeping hands that has the thin aluminum bezel around it, I just want to replace mine with this style. Mike Edited October 7, 2015 by Mhemperly
Marauder Posted October 6, 2015 Report Posted October 6, 2015 What model is it Mike? Spruce is showing a couple of flat units. Wonde if one of them superseded the version you have. http://www.aircraftspruce.com/menus/in/chronometers_davtron.html Sent from my iPad using Tapatalk 1
Marauder Posted October 6, 2015 Report Posted October 6, 2015 This is the full line for the Davtron series. Hard to tell from the pictures if the M802 or M850 might work. http://www.davtron.com/overview.php#800 Sent from my iPad using Tapatalk
Andy95W Posted October 6, 2015 Report Posted October 6, 2015 does anyone know if this clock can still be purchased from davtron? Or does anyone know of one for sale or where I can even find a used one? ive looked on davtron's site and can't find it Mike $50 on eBay, looks exactly like yours, just over 1 day left. http://www.ebay.com/itm/Davtron-M800-Aviation-Chronometer-for-14-volt-system-/321880964417 Or it looks like to get it repaired you just send it straight to Davtron, and the repair is a flat $70. http://www.davtron.com/support.php
Marauder Posted October 6, 2015 Report Posted October 6, 2015 $50 on eBay, looks exactly like yours, just over 1 day left. http://www.ebay.com/itm/Davtron-M800-Aviation-Chronometer-for-14-volt-system-/321880964417 Or it looks like to get it repaired you just send it straight to Davtron, and the repair is a flat $70. http://www.davtron.com/support.php I'm not sure that is his unit. With the exception of the blue buttons, the lettering on the unit is different. It also appears his unit is a flat surface square. The eBay unit looks like a 2 1/2" hole mountable. Sent from my iPad using Tapatalk
MHemperly Posted October 7, 2015 Author Report Posted October 7, 2015 This is the full line for the Davtron series. Hard to tell from the pictures if the M802 or M850 might work. http://www.davtron.com/overview.php#800 Sent from my iPad using Tapatalk thanks marauder. The picture I posted is not my panel. I just like that clock because it fits the yoke without using the thin plate that is used with the anolog clock with the sweeping hands. Mike
MHemperly Posted October 7, 2015 Author Report Posted October 7, 2015 $50 on eBay, looks exactly like yours, just over 1 day left. http://www.ebay.com/itm/Davtron-M800-Aviation-Chronometer-for-14-volt-system-/321880964417 Or it looks like to get it repaired you just send it straight to Davtron, and the repair is a flat $70. http://www.davtron.com/support.php close but not exactly what I'm looking for. The picture I posted is not my panel. I guess I should of specify that in my post. I think davtron use to make a clock specifically for our vintage mooney yoke that eliminates the thin aluminum bezel that goes over the round anolog clock. Mike
Mooneymite Posted October 7, 2015 Report Posted October 7, 2015 The Davtron 877 fits into my yoke perfectly. Uses a double A battery, so except for the illumination is completely self contained.
MHemperly Posted October 7, 2015 Author Report Posted October 7, 2015 The Davtron 877 fits into my yoke perfectly. Uses a double A battery, so except for the illumination is completely self contained. I may have To go this route if I can't find the square one that fits perfect with just the two screws at each corner mike
