JaredDavis Posted August 24, 2015 Report Posted August 24, 2015 Hi, Anyone know the closest mechanic with travel boards? I need to check my flaps. After the flap splice plate was installed, the plane pulls to the left in cruise and landing. The left flap is higher than the aileron in cruise. It used to be flush (as far as I can remember) Quote
aviatoreb Posted August 24, 2015 Report Posted August 24, 2015 I used to use Landmark at KSYR when I had a DA40. They seemed like a fully equipped shop and while I never saw their runner boards I would guess they have them. Quote
yvesg Posted August 24, 2015 Report Posted August 24, 2015 Check with Clarence on this forum. He is An MSC and I think he has the equipment. About an hour and a half flight from you. Yves Quote
Guest Posted August 24, 2015 Report Posted August 24, 2015 I have a full set of travel boards. Wouldn't Weber Aircraft be closer? Clarence Quote
aviatoreb Posted August 25, 2015 Report Posted August 25, 2015 ...yeah - if you are going to fly - its an hour from you to Weber. Quote
