JaredDavis Posted July 19, 2015 Report Posted July 19, 2015 Went to fly the plane and found a puddle of hydraulic fluid under the belly. As far as we can tell there is a leak in the line near a clamp point. Has anyone had to replace a brake line in the belly? How long did it take? It is part 850000-23 which just happens to be the longest line. Not sure if it can be replaced without bending it in place. Any hints for the ap?
N601RX Posted July 19, 2015 Report Posted July 19, 2015 When I added copilot brakes I had to form several of the tubes to fit. I ordered the aluminum tubing from Spruce in 6' pices and had to formed and flared to fit. Depending on where the leak is and the condition of rest of the tube it may be possible to cut out the bad inch or so, flare the ends and put a union in the middle.
JaredDavis Posted July 19, 2015 Author Report Posted July 19, 2015 Thanks for the replies. The lines may be original. It may be time.<g> The break is not in an easy to access area. The AP wanted to investigate a flexible hose solution vs Al tubing. Any thoughts? I was leaning towards the Al tubing as it worked for the first 50 years. But, I have no idea if it can be installed pre-bent which was his concern. Flexible hose would go in easier but would have reduced clearances to push tubes.
carusoam Posted July 20, 2015 Report Posted July 20, 2015 My 65 C got all of its rubber brake lines replaced after about 45 years... The cherry juice brake fluid was harmful to their health. New materials are better suited for the job. Doing it at annual was relatively painless. They are the low pressure return lines, not very high tech or expensive. Hope that helps, -a-
N601RX Posted July 20, 2015 Report Posted July 20, 2015 A long length of flex hose might make the brake on that side feel softer due to slight expanding when under pressure. Unless you have a 1 pc belly the area the brake lines run through isn't easily accessible. There may be some additional access by removing the rear seat and through the inspection panels under the seat.
JaredDavis Posted July 20, 2015 Author Report Posted July 20, 2015 Thanks. What AL material and wall thickness is best?
N601RX Posted July 20, 2015 Report Posted July 20, 2015 Here is what the copilot brake kit called for. The older models use the tubing shown in item#1 and the later model J, K use what is shown it #5.
JaredDavis Posted July 20, 2015 Author Report Posted July 20, 2015 Thanks again. I don't see how one rigid line is going to fit. Any issues using two relatively straight lines with a 90 elbow?
N601RX Posted July 20, 2015 Report Posted July 20, 2015 Be aware that all aircraft flares are 37 deg not 45. Based on 43.13 is seems like you could replace it in 2 pieces. From AC43.13 Repair of Metal Tube Lines. Minor dents and scratches in tubing may be repaired. Scratches or nicks not deeper than 10 percent of the wall thickness in aluminum alloy tubing, that are not in the heel of a bend, may be repaired by burnishing with hand tools. Replace lines with severe die marks, seams, or splits in the tube. Any crack or deformity in a flare is unacceptable and cause for rejection. A dent less than 10 percent of the tube diameter is not objectionable unless it is in the heel of a bend. A severely-damaged line should be replaced; however, it may be repaired by cutting out the damaged section and inserting a tube section of the same size and material. Flare both ends of the undamaged and replacement tube sections and make the connection by using standard unions, sleeves, and tube nuts. If the damaged portion is short enough, omit the insert tube and repair by using one union and two sets of connection fittings.
