Mooneymite Posted July 28, 2014 Report Posted July 28, 2014 You are obviously parked across an isogonic line. :-) Quote
47U Posted July 29, 2014 Report Posted July 29, 2014 "Now my biggest gripe is why they are a degree off from each other?" The horrors... I was on a SWA flight recently and following the flight on the onboard internet tracker... I was surprised to see the heading is calculated to the third decimal place. That right there is precision! Are both Aspens running the same software version? Do they use the same remote compass/flux valve? Is the wiring from the remote compass shielded? Or is the heading actually GPS driven? If you figure it out please post the reason why. Being currently unemployed, this question is the highlight of my day. Quote
Marauder Posted July 29, 2014 Report Posted July 29, 2014 "Now my biggest gripe is why they are a degree off from each other?" The horrors... I was on a SWA flight recently and following the flight on the onboard internet tracker... I was surprised to see the heading is calculated to the third decimal place. That right there is precision! Are both Aspens running the same software version? Do they use the same remote compass/flux valve? Is the wiring from the remote compass shielded? Or is the heading actually GPS driven? If you figure it out please post the reason why. Being currently unemployed, this question is the highlight of my day. The Aspens have completely separate AHRS and remote compass hardware. I usually will see a degree or two difference between them. So much better than my old DG and wet compass days. I do a compass ramp check when I taxi out from my hangar and there is a known 150 degree heading that is lined up with the taxiway line. I line up on it and read the three sources (two Aspens and the vertical card compass). I also read the runway heading as a double check. So much nicer only seeing a couple degree difference. As for the wiring, there is a shielded cable that run from each Aspen. There is also heading information provided by the GPS, but this is used to determine a few parameters like winds aloft and the important wind correction. A good example is this picture. The heading is 358 degrees which is being flown to maintain the 004 degree course. The winds aloft are at 301 at 14 knots. The blue arrow shows the Aspen ground course marker that shows your course across the ground (it is on the end of the CDI arrow). Amazing to see how far technology has come! 1 Quote
N201MKTurbo Posted July 29, 2014 Report Posted July 29, 2014 How did this thread about ancient DGs get hijacked to an Aspen thread? Â FWIW in my old M20F it had the old DG removed and replaced with a modern DG by the previous owner. All he did was enlarge the hole, hook up the vacuum and filter hoses and enlarge the hole in the plastic overlay. It didn't look bad. 2 Quote
Marauder Posted July 29, 2014 Report Posted July 29, 2014 How did this thread about ancient DGs get hijacked to an Aspen thread? FWIW in my old M20F it had the old DG removed and replaced with a modern DG by the previous owner. All he did was enlarge the hole, hook up the vacuum and filter hoses and enlarge the hole in the plastic overlay. It didn't look bad. Hmmm... Probably because old compasses are BORING! Quote
N201MKTurbo Posted July 29, 2014 Report Posted July 29, 2014 I guess I'll have to put a video game in my dash so I can play with you guys... 1 Quote
ryoder Posted July 30, 2014 Author Report Posted July 30, 2014 I am squawking 7500 on this thread Aspen actually fits in nicely with this thread because I was considering not spending a dime on the old steam gauges and going with the vfr aspen or a g500. I will probably have one thousand bucks into a new gyro that could go into glass instead. 1 Quote
carusoam Posted July 30, 2014 Report Posted July 30, 2014 My favorite displays are analog... But they are digital instruments under the needles, same with the radios... The 90’s were unique. Back to the point... Get an accurate display of your data. The precision of three numbers past the decimal is not as important. Rate of change is a piece of information that is good to discern... Newer instruments handle rate of change information better than the WWII era stuff. If you like engineering detail while you fly, save money while you select your Aspen. If you like to pay extra to have to think less, save more money while you select your Garmin. I really like the wind direction and speed data IN the cockpit. I have seen the results of somebody landing with the wind.... There probably are a couple of hard to explain skid marks at the end of your runway??? The WWII era windsock can be difficult to find, see, and interpret... If you can't discern if the sock is pointing towards you or pointing away.... Go around! I tried to come back on track... -a- Quote
scottfromiowa Posted July 31, 2014 Report Posted July 31, 2014 I am squawking 7500 on this thread Aspen actually fits in nicely with this thread because I was considering not spending a dime on the old steam gauges and going with the vfr aspen or a g500. I will probably have one thousand bucks into a new gyro that could go into glass instead. That's 1AMU newb...Welocme to the Cheap-Bastard's club... 2 Quote
Marauder Posted July 31, 2014 Report Posted July 31, 2014 I guess I'll have to put a video game in my dash so I can play with you guys... Â Only problem with this video game is there is no reset button. Quote
